My Tranny mods....opinions please
Old Jul 31, 2005 | 09:36 PM
TypeRPaul's Avatar
Default My Tranny mods....opinions please
My R has the mods listed below and the stock clutch is getting a bit long in the tooth. My plans are to mainly drag and auto X her as well as use her for my daily driver till I finish school (1 year) I have a the resources so I figured that if I have the tranny out I might as well do everything all at once so here is my mod list:
-Clutchmasters stage 3 clutch
-Fidanza Light weight Flywheel
-ATS 4.9 final drive (with jdm 1st gear, etc)
-Omni power clutch master cylinder
all of these should run me around $1600 with me doing all the labor and it will give me a chance to finally put my rear tranny mount in from jimfab. My question is aside from brand opinions are there any other mods you would do while the tranny is out? Thank in advance
Old Jul 31, 2005 | 09:44 PM
RagingAngel's Avatar
Default Re: My Tranny mods....opinions please (TypeRPaul)
Dun really have an opinion on the 4.9....but if you were to save a bit of cash, the 4.785 is a good option.
Then you could add a taller 1st gear too.... to make it sort of useful.
I think the clutch is a bit extreme, unless you plan to do some mods in the future we don't know about that requires this kind of holding power.
The flywheel is good I use a CM unit which is similar
Oh and get some shifter bushings and relube and/or replace the plastic race for your shifter.
Old Jul 31, 2005 | 11:29 PM
egtwincam's Avatar
you dont need the omni mc. id rather get gear speed carbon coated syncho's...
Old Aug 1, 2005 | 04:34 AM
Bbasso's Avatar
Default Re: (egtwincam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egtwincam &raquo;</TD></TR><TR><TD CLASS="quote">you dont need the omni mc. id rather get gear speed carbon coated syncho's...</TD></TR></TABLE>
????????????? huh?
Old Aug 1, 2005 | 05:55 AM
Default Re: (Bbasso)
Clear as mud yO!
Do you even know what the Omni MC does? Albeit the gearspeed syncros should be considered.... but somehow, Bbasso's "Huh?" sums it up perfectly....
Old Aug 1, 2005 | 06:10 AM
1GreyTeg's Avatar
Default Re: (RagingAngel)
Yeah, what do you need a new clutch MC for?
The 4.93 FD depends on your intended use, but I like mine quite a bit.
Bbasso, what clutch did you have when I drove your car? I thought it was purdy stiff, felt like a workout, not really to my liking. I personally like the Toda or OEM clutch, but again I'd expect that'd be preference and application related.
LW flywheel is a hoot, many have had good luck with Fidanza, I personally have a Toda and love the feel combined with the FD.
Old Aug 1, 2005 | 08:11 AM
Default Re: (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, what do you need a new clutch MC for?
I think this is what the original poster is after with the Omni MC.
-50% Reduction in Clutch Pedal Travel
-User Adjustable Clutch Release Point
-Improved Clutch Accuracy & Pedal Feel
-Longer Transmission Synchro Life
-Faster Recovery From Missed Gears
-Restores Timing and Synchronization Between Short Shifter and Clutch Pedal.
*5 year warranty
Old Aug 1, 2005 | 08:47 AM
TypeRPaul's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RagingAngel &raquo;</TD></TR><TR><TD CLASS="quote">
*5 year warranty
Yep, i think it would be fun and help with the delay of the hondata launch control. As for the clutch lvl i figure i might be getting my head p&p and built with toda B's so i could probably take advantage of the stronger hold.
Old Aug 1, 2005 | 08:48 AM
TypeRPaul's Avatar
btw what are speed carbon coated syncho's? and how much are they?
Old Aug 1, 2005 | 08:56 AM
Default Re: (TypeRPaul)
http://www.gear-speed.com/deta...nchor
Check eBay as I seem to recall they have auctions running all the time.
Old Aug 1, 2005 | 09:56 AM
TypeRPaul's Avatar
what are the advantages of these? last longer?
Old Aug 1, 2005 | 10:06 AM
Bbasso's Avatar
ACT XT-SS But that was when the throw bearing was going... Now it's a ton smoother thanks to Will installing a new one.
Old Aug 1, 2005 | 10:07 AM
Bbasso's Avatar
No need to go thru the auctions, just call them up. I bought a set from them for my R and it was 275 shipped, nice quality and very good service.
Old Aug 1, 2005 | 11:49 AM
TypeRPaul's Avatar
Bbasso are the syncros really worth the 275? at almost 50,000 mi the only gear that i have problems with is 1st at a stop, it occasionally doesnt want to go in.
H22Prelude420
May 26, 2010 06:15 PM
slix_eg
May 10, 2007 03:39 PM
dbsharp
Sep 1, 2006 07:39 AM
dopefeen
Jul 15, 2006 09:04 AM
ITR21
May 1, 2003 07:02 PM
