code 36 on jdm P13 ecu (Traction control) how to disable??
Old Jul 31, 2005 | 08:53 PM
boostedcivic805's Avatar
Default code 36 on jdm P13 ecu (Traction control) how to disable??
anyone know how to disable this or the pinout.
Old Jul 31, 2005 | 10:06 PM
Default Re: code 36 on jdm P13 ecu (Traction control) how to disable?? (boostedcivic805)
bump
Old Aug 1, 2005 | 12:45 AM
pentaq's Avatar
Default Re: code 36 on jdm P13 ecu (boostedcivic805)
Leave it. It doesn't influence on the performance of your car.
Old Aug 1, 2005 | 03:47 AM
The Phil's Avatar
Default Re: code 36 on jdm P13 ecu (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Leave it. It doesn't influence on the performance of your car.</TD></TR></TABLE>
If his car throws another CEL, he won't know it because the CEL is already lit.
Old Aug 1, 2005 | 05:19 AM
pentaq's Avatar
Default Re: code 36 on jdm P13 ecu (The Phil)
I think it's the same type of CEL like ELD (20). It is in the ECU, but not shown all the time. Of course it will be blinking the code while doing diagnostics.
Old Aug 1, 2005 | 07:19 AM
Duane_in_Japan's Avatar
You will just have to keep checking your codes every month, they will stack up.
Old Aug 1, 2005 | 09:13 AM
Default Re: code 36 on jdm P13 ecu (Duane_in_Japan)
yea it does affect the performance its like a rev limiter or fuel cut. and it revs out at like 6500 it only happens at full throttle though. did i meation that its a h22a4 in a 93 civic hatch.
Old Aug 1, 2005 | 01:02 PM
Chivas's Avatar
I have been running a P13 with TCS on my JDM H22 for over two years and never had any adverse performance problems. The cel does not light up in normal conditions. It only comes on when you check for codes during diagnostic. If your car is not revving past 6500 then it is due to another problem.
Old Aug 14, 2005 | 03:41 PM
SiRTifiedacc's Avatar
Default Re: code 36 on jdm P13 ecu (Chivas)
maybe u should just toss that p13.. =]
Old Aug 14, 2005 | 05:44 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">If his car throws another CEL, he won't know it because the CEL is already lit.</TD></TR></TABLE>
36 is a soft code, it doesnt light the CEL all the time, only comes up when u check for it by jumping the connector
H23forlife
Aug 24, 2007 11:37 AM
CHEFH22HATCH
Jul 7, 2006 02:57 PM
h22zexhatch
Apr 12, 2005 01:30 PM
esca
Oct 14, 2004 06:34 PM
