95' LS Integra Dc4 and i need help!!
Old Jul 31, 2005 | 06:24 PM
Squad1's Avatar
Default 95' LS Integra Dc4 and i need help!!
i have a 95 integra. and i had to completely change over the under dash harness. and put everything back together.. but then later on i found out the my cruise control, and moonroof doesnt work at all. i dont even know why. i checked all the fuses, but theyre all good. samething happend to my taillights foglights( JDM FRONT ) brake lights, signal lights, and hazards.
hope you guys could help me out..
Old Jul 31, 2005 | 06:58 PM
LSvtec03's Avatar
Default Re: 95' LS Integra Dc4 and i need help!! (NAisbest)
make sure everything is plugged in and grounded, and that all the switches are good. might as well check the bulbs, while you're at it.
Old Jul 31, 2005 | 07:18 PM
b18cDA's Avatar
Default Re: 95' LS Integra Dc4 and i need help!! (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">make sure everything is plugged in and grounded, and that all the switches are good. might as well check the bulbs, while you're at it.</TD></TR></TABLE>
Old Jul 31, 2005 | 07:56 PM
Squad1's Avatar
did check the switches. and maybe it was the ground that i piled up. ( behind the fuse box ) gotta check on that..
Old Aug 4, 2005 | 12:31 PM
Squad1's Avatar
ttt
MikendablkDB8
Lighting
Apr 18, 2009 11:17 AM
JDM Dylan
20
Feb 28, 2008 10:45 PM
db_4zero8
Jun 5, 2007 02:10 PM
ToiletFetusSushi
Aug 23, 2006 01:58 AM
del_orson
Mar 22, 2005 07:48 PM
