My back lights wont turn on, please help.
a little bit after i got the car i notice the brake lights werent workin but the regular one were, except one bulb which i tried to change but after words none of my back lights were working except my turning lights. can some one please help me.
Re: (yoffer)
get a multimeter and test the bulb socket in the back to see if your getting power ...if not cheeck fuses and try and hunt down the wire gremlin
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">checked the wiring? fuses? brakelight switch?
x2 on fuses, also check ur harness and see if anything is unplugged
Re: (d[sick]sTeena)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d[sick »</TD></TR><TR><TD CLASS="quote">sTeena]
x2 on fuses, also check ur harness and see if anything is unplugged</TD></TR></TABLE>
u mean x3 ?
u mean x3 ?
H-T White Ops
Re: (JDM Dylan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Dylan »</TD></TR><TR><TD CLASS="quote">no my horn doesn't work</TD></TR></TABLE>
Does the horn circuit have power? If it does you're good, but if it doesn't that might be the cause of your light troubles. Again, sounds stupid, but trust me.
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">check the brakelight switch behind the brake pedal.. </TD></TR></TABLE>
if the brake lights worked before he messed with the fuse, i wouldnt be the "brakelight switch" behind the pedal, now would it?(unless there is some kind of supernatural coincidence) on you
Re: (x0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x0! »</TD></TR><TR><TD CLASS="quote">he didnt say they worked before. he said after he got the car he noticed they werent working.
nice try though </TD></TR></TABLE>
didn't read that up there, i was cloooose though
doesnt sound like you've checked that horn fuse out... check the bulbs, fuses, and that switch i guess, and keep us posted.
Stunna MIKE
01-30-2006 03:36 PM
