please help
I have a 92 cx hatchback, i was driving and then my head lights, main not the brights, running lights and tripple pillar lights and gauge lights just went out, so I checked the fuses under the dash, all are good, so I then check the fuses under the hood all are good, so then i get a new dimmer switch, and still nothing works, so I resolder the old dimmer switch nothing still, and then i check all my grounds and trace the wiring and every thing is good, so im stuck and dont know what else to look for so any help would be good, yes I searched all ready but the other searches were like try changing dimmer, did that so im stuck please help
Something has to be grounding out somewhere, a stray peice of wire, etc. Double and triple check it all. Unplug or undo the wiring for the gauge pod. See if that fixes. Triple check the fuses. Replace for the hell of it.
