fuel pump ?
ok my car cranks and doesnt turn over.its getting spark but no fuel, so i took the incoming line to the fuel filter off and tried to start it no fuel what so ever...so i thought it was the fuel pump relay or the fuel pump.then i learned there is no fuel pump relay just a main relay. can someone tell me what the hell iy might be. it is a 92 lude with an h22 swap
in case you meant to ask "where the hell is it", its above the pedals. its a small rectangular grey box. if you swap that out for a known good one and you still have no fuel pressure at all, suspect the fuel pump.
Cameron60
Jan 16, 2007 06:04 PM
