jdm d15b swap is it recomended to change axles?
Old Jul 31, 2005 | 03:14 PM
CivicHP's Avatar
Default jdm d15b swap is it recomended to change axles?
before i droped in my jdm d15b vtec i had a d15b7 non vtec is it recomended to switch axles with some that came off a vtec motor or mine are fine will they brake later?
Old Jul 31, 2005 | 03:26 PM
dewoine's Avatar
Default Re: jdm d15b swap is it recomended to change axles? (CivicHP)
i did a d15b swap in my 93 coupe last year and i kepted everything from my d15b7. im still riding on the same axles that was on the car when i bought it so you should be fine.
Old Jul 31, 2005 | 03:28 PM
CivicHP's Avatar
do you push it alot do any track or drag?
Old Jul 31, 2005 | 03:38 PM
dewoine's Avatar
Default Re: (CivicHP)
i only been to the track once ever but never had any problems with my axles plus im dropped like 4 1/2 inches and there in akward shapes and they still holding up well
Old Jul 31, 2005 | 03:47 PM
CivicHP's Avatar
Default Re: (dewoine)
4 1/2 are you insane. ok thanks
Old Jul 31, 2005 | 03:55 PM
dewoine's Avatar
yeah its low as hell i dont know if its 4 1/2 really but the tires are tucked under the fenders. all i can say is that those axles are strong as hell to be riding like that this hole time.
Old Jul 31, 2005 | 04:03 PM
nighttrain33's Avatar
English anyone? j/k. It is usually recommended to swap axles as well. Anything routine maintenance is generally considered commonplace to replace when doing a swap as you never know how it was driven b4. But, it is all up to you.
-Shane
Old Jul 31, 2005 | 05:17 PM
RedDC5's Avatar
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">English anyone? j/k. It is usually recommended to swap axles as well. Anything routine maintenance is generally considered commonplace to replace when doing a swap as you never know how it was driven b4. But, it is all up to you.
-Shane</TD></TR></TABLE>
I agree. If your going to do something, might as well do it right, stay safe and switch your axles out, it wont hurt anything, you may save money up front, but in the long run it will save you time and effort to go on ahead and switch your cv's out. Just my opinion.
Old Jul 31, 2005 | 06:40 PM
red-eg6's Avatar
Default Re: (4doorEG)
i got new axles put in my 94 hb when i swaped my jdm d15b and im happy with em
Old Jul 31, 2005 | 06:55 PM
CRXified's Avatar
Default Re: (red-eg6)
y would u change axels? they are the same, unless they are clicking i wouldnt change them. dont fit what aint broken
Old Jul 31, 2005 | 06:59 PM
red-eg6's Avatar
Default Re: (CRXified)
well mine were broken lol
Old Jul 31, 2005 | 07:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">y would u change axels? they are the same, unless they are clicking i wouldnt change them. dont fit what aint broken </TD></TR></TABLE>
So if you were to swap, you wouldn't change the plugs, wires, dizzy, water pump, timing belt, etc? Just about anyone that I know would. But ok.
-Shane
Old Jul 31, 2005 | 08:47 PM
SpydiR's Avatar
unless they click, leave them alone. it seriously takes like 15 minutes to pull the axles out. it's more of a pain in the *** to get to the oil filter than remove the axles IMHO. with a jdm d15b you're not going to make 1000hp out of the box so your stock axles are fine.
DAslammed
Nov 18, 2007 09:01 PM
flyingduck04
Jan 16, 2004 08:49 AM
superfuji57
Sep 25, 2002 03:09 PM
