Turbo cams
Old Jul 31, 2005 | 12:20 PM
rizen's Avatar
Default Turbo cams
I'm getting ready to put the car down and begin the rebuild process.
I've done some searching and didn't find a whole lot on cam suggestions. A lot of people are suggesting using the stock ITR cams, but how much HP are they good for?
I know I'd need a cam profile with short duration and high lift. I see Crower has an application, but all I hear is about how their cams break and destroy motors.
Suggestions from the darkside?
Old Jul 31, 2005 | 12:45 PM
PM-Performance's Avatar
Default Re: Turbo cams (rizen)
do yourself a big favor and leave the stockers in.
Old Jul 31, 2005 | 01:52 PM
rizen's Avatar
That's what Ive been reading... I guess that should do.
Any idea when the stockers become the bottleneck?
Old Jul 31, 2005 | 02:02 PM
ZygSpeed's Avatar
Default Re: (rizen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizen &raquo;</TD></TR><TR><TD CLASS="quote">Any idea when the stockers become the bottleneck?</TD></TR></TABLE>
I'd guess in the 450-500 whp range that a change of cams might make a difference.
You really should check with a few notable turbo shops for their professional opinions.
Old Jul 31, 2005 | 02:06 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizen &raquo;</TD></TR><TR><TD CLASS="quote">Suggestions from the darkside?</TD></TR></TABLE>
leave the stock cams.. whats your hp goal?
Old Jul 31, 2005 | 02:19 PM
rizen's Avatar
Looking to get around 420-450 on 93 and 500+ on race
Old Jul 31, 2005 | 02:33 PM
vtec.dc2's Avatar
Default Re: (rizen)
personally i'd stick with oem cams.. but heres a link to 600+ whp on itr cams.. https://honda-tech.com/zerothread?id=1069197.. from what i read gsr can provide for more midrange, at that much hp cams can make a difference, then again, do you care if you make 30 less hp or have to run extra psi of boost to compensate?
Old Jul 31, 2005 | 03:55 PM
Aquafina's Avatar
Default Re: (vtec.dc2)
Rocket Motorsports M21X cams/valvetrain.
Here they are in a 2.0 at 19psi, clutch slipping badly, destroyed itself after this run.
Old Jul 31, 2005 | 06:01 PM
Chris F's Avatar
Save the money, you can spend it better elsewhere. Stock GSR/ITR cams are good turbo cams. (as already mentioned)
-Chris
Old Jul 31, 2005 | 06:45 PM
DontBlink's Avatar
Default Re: (rizen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rizen &raquo;</TD></TR><TR><TD CLASS="quote">Looking to get around 420-450 on 93 and 500+ on race</TD></TR></TABLE>
if thats what your looking to make power wise then you'll be fine with stock cams. im still running them hp numbers are in my sig and i didnt get a race gas tune yet.
Old Jul 31, 2005 | 07:09 PM
ZygSpeed's Avatar
Default Re: Turbo cams (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Save the money, you can spend it better elsewhere. Stock GSR/ITR cams are good turbo cams. </TD></TR></TABLE>
My turbo motor was using GSR cams, going with at least an ITR intake this time around w/cam gear tuning.
Old Jul 31, 2005 | 07:26 PM
rizen's Avatar
Thanks for the info guys...
It cleared up a lot of thoughts about my build.
Old Jul 31, 2005 | 07:27 PM
ringgold's Avatar
Default Re: Turbo cams (zygspeed)
Cortney Green (uglyasscivic h-t name) made a little over 800whp on his stock GSR cams I do believe and this is in a street car. Also I have seen over 600whp with stock ITR cams. Personally I would leave the stock cams in there myself cant get much better than that it seems when going turbo on the b series engines.
Old Jul 31, 2005 | 07:37 PM
thk's Avatar
thk
Members Only
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">My turbo motor was using GSR cams, going with at least an ITR intake this time around w/cam gear tuning.</TD></TR></TABLE>
"This time around?" And here I thought you were going to leave 151 basically "stock".
EJ8 GSR-T
Jul 21, 2006 11:02 PM
pulpdeem
Mar 5, 2006 01:54 PM
9341civic
Jun 1, 2005 12:31 PM
Old_Honda
Jun 25, 2004 07:53 PM
CimorelliCRX
Jul 27, 2002 02:04 PM
