CM flywheel replacable friction surface?
Old Jul 31, 2005 | 12:04 PM
theo99gsr's Avatar
Default CM flywheel replacable friction surface?
Is anyone in here using a clutch masters flywheel and had to replace the friction surface? I'm getting ready to replace my clutch for a new stage 4 comp clutch and need to know if it is necessary to replace this. I've been using the CM stage 3 clutch. I know that you should resurface a flywheel when you replace the clutch but shouldnt this be stronger than a stock flywheel? Also i dont have alot of money so i really dont what to buy parts i dont need. So if anyone has any insight about this flywheel let me know. thanks.
Old Jul 31, 2005 | 03:31 PM
theo99gsr's Avatar
Default Re: CM flywheel replacable friction surface? (theo99gsr)
no one has had experience with this flywheel???
Old Aug 1, 2005 | 06:54 AM
clutchmasters's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theo99gsr &raquo;</TD></TR><TR><TD CLASS="quote">Is anyone in here using a clutch masters flywheel and had to replace the friction surface? I'm getting ready to replace my clutch for a new stage 4 comp clutch and need to know if it is necessary to replace this. I've been using the CM stage 3 clutch. I know that you should resurface a flywheel when you replace the clutch but shouldnt this be stronger than a stock flywheel? Also i dont have alot of money so i really dont what to buy parts i dont need. So if anyone has any insight about this flywheel let me know. thanks.</TD></TR></TABLE>
Good question, once you get the clutch out of the car I would examine the flywheel for any warpage, put a straight edge down over the surface and check for day light between the surface and your straight edge. If you can see excessive gap you might want to get the replacable insert (only about $100).
gmadsen100
15
Nov 7, 2006 09:05 PM
xintegr
Mar 26, 2006 06:25 PM
Hondasaurs
Mar 3, 2002 09:24 AM
Keane Rated R
Jan 13, 2002 11:45 AM
