How to tell if you have a Blown Headgasket or cracked Cylinder head?
Hey guys just the the topics says....
How can i tell if i have a blown headgasket or cracked cylinder head?
I have performed a leak down test which was 8% on all cylinders and also a compression test of 270 on all cylinders. Which showed no sign of a blown headgasket. But i have alot of air going into my cooling system and i wanted to know if there was a test i could perform which would prove which of the 2 the air is comming from. Thanks !
https://honda-tech.com/zerothread?id=1322498
This morning i finally got a better clue on a blown headgasket........finally got some air comming out the resivor lines....bubbles like a champ. Weird thing is that no air comes out of the lines while at idle. I bleed the system. Idled for about 45 min. ALL GOOD. Took for test drive about 30 min into it the gauge skyrockets. Looked at the resivor and it was overfilled with air bubbles oozing out of it.
NOW how do i tell if its a blown headgasket or a cracked cylinder head?
Heres a great article on how to tell if you have a blown head gasket also shows how to prevent one!
http://freecarsupport.com/blog/2012/...t#.UIsqSWk-t7Q
do a block test. vatozone rents out a little kit and you put on top of your radiator with a special fluid that turns yellow with a blown headgasket
I'm having the same problem on my b20v..
Cap is new, thermostat, water pump. No visible coolant leaks in engine bay or on floor.
After driving for about 30 minutes the temp starts to rise. Tomorrow I'll check coolant level to see if it has gotten lower. If that's the case I guess I'll be pulling the head out.
With cooling issues there are a lot of things it could be. But, with your leak down and compression results being good and equal I am leaning towards it being a coolant flow / pressurization (cap) issue.
I got a similar issue. I got a 2003 honda civic with overheating issues. At first it was a intermitten issue and would some how lose coolant and mechanic says it was electrical issue with fan and he said he fixed it but of course that didnt help at all. Then it started to get worse air was bubbling in resevoir and then car wouldnt start. Engine was flooded and rust was on sparkplugs, i knew then that it was the head gasket. Bought new radiator cap, thermostat, waterpump, headgasket and will be doing a coolant flush. I took off head is taken off and guess what i found...no blown head gasket. I took head to machine shop and they said it was fine. I dont see any cracks in cylinders but i can always check again to make sure but idk what caused all of this. Please help!!!
doublek
Aug 1, 2005 01:34 PM
