Factory Spoiler/Wing Removal
97 GS factory wing with center break light
When taking off, do i need to cut the wires to the break light, or is their a harness somewhere? I can't seem to find the harness if there is one, and I do not want to just cut the wires in case I ever want to put the wing back on. Thanks.
no theres absolutley no need to cut the wires. take the 2or3 bolts out so the spoiler comes off then pop the interior panel under the hatch theres about 10 pops u have to pop out of place then find the connector i belive its gray and it should be small enough to fit through the whole in the hatch. goood luck just use a flat head to get started with the pops
i am bumping my old thread...
does anyone know what the rubber pieces are called/part numbers from home depot to fill the holes? i went there and couldn't find anything, and the guy i asked had no idea what i was talking about.
home depot has them , i just got some last week and the fit perfect no leaks.
or go to any hardware store but i can t recall the exact name for it.
https://honda-tech.com/zerothread?id=719658
the package said hole plug i think one of the sizes ...7/16 but u can just get a # of
different sizes , they run for about 39c
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectac »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=719658
different sizes , they run for about 39c</TD></TR></TABLE>
thank you for that link!
just swing by a hardware shop and pick up a bunch of hole plugs. mine were plastic and ran about a quarter each. spent less than two bucks and just painted them with touch up. threw on a type r spoiler and you can barely tell
Eg_TypeR
Paint and Body
Feb 25, 2008 05:22 PM
