What's with all the gauges?
Old Jul 31, 2005 | 08:51 AM
RA122324's Avatar
Default What's with all the gauges?
Hopefully someone out there can help me to understand this. I bought an A-pillar with a 3 gauges on it (Oil Pressure, A/F Ratio and Battery voltage) for my '88 CRX Si. I was browsing around trying to figure out how to hook them up. For some reason I keep coming across things like this:
Is there really any point to have gauges on the complete other side of the dash where they aren't convinient to read? Not trying to knock on anyone I just wanna know the reasons behind it (if any).
Old Jul 31, 2005 | 09:00 AM
Crx Jimmy's Avatar
Default Re: What's with all the gauges? (knwldge54)
that gauge is pretty retarded, not only cant you see it from the driver seat its looks like crap, what did they cut a hole in the dash with a rusty pocketknife? better yet have you ever seen the gauges in the glove compartment, those are real useful
Old Jul 31, 2005 | 09:02 AM
goforbroke's Avatar
MEAT PATTY
Default Re: What's with all the gauges? (Crx Jimmy)
Some people are just guage ******.
SiR Inspired ED7's Avatar
imo gauges are wack,
Old Jul 31, 2005 | 09:18 AM
Mr.Saturn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">that gauge is pretty retarded, not only cant you see it from the driver seat its looks like crap, what did they cut a hole in the dash with a rusty pocketknife? better yet have you ever seen the gauges in the glove compartment, those are real useful </TD></TR></TABLE>
Right side gauges might be useful if you are having someone in the passenger seat take notes or change something based on the readings... but I would prefer just to remove the gauges after that.
Old Jul 31, 2005 | 09:24 AM
mr_valentino20032000's Avatar
Default Re: What's with all the gauges? (Mr.Saturn)
someone needs to find pics of that orange caviler from a car show i saw in a mag.
they had like 17 guages or something like that. i used to joke about it, and have switches and ****, so starting my car would be like prepping a plane for take off
Old Jul 31, 2005 | 11:17 AM
crx-treme's Avatar
Default Re: What's with all the gauges? (mr_valentino20032000)
i think guages are kinda ricey, but if ur boosted guages are a must. also they must have good placement such as what ur doing the a pillar. i will def have gauges next year
Old Jul 31, 2005 | 11:22 AM
TheBobFather's Avatar
Default Re: What's with all the gauges? (crx-treme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme &raquo;</TD></TR><TR><TD CLASS="quote">i think guages are kinda ricey, but if ur boosted guages are a must. also they must have good placement such as what ur doing the a pillar. i will def have gauges next year </TD></TR></TABLE>
I agree...but done tastefully
Old Jul 31, 2005 | 02:02 PM
RCautoworks's Avatar
Default Re: What's with all the gauges? (88 Crx Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">imo gauges are wack, </TD></TR></TABLE>
Not when they serve a purpose.
An oil pressure gauge is a must, specially when you are gonna be doing engine work on an engine going into that car.
And I also like coolant temp gauges, because the stock gauge will stay at the same point, when the temp is either 130f or 220f, it always stays the same. And when you try to do things to help your engine temp stay down, an aftermarket gauge is a must.
Old Jul 31, 2005 | 02:03 PM
RA122324's Avatar
This is a pic of the gauge pillar that I bought. Seems funtional to me.
I got mine for $125 and it's got the A/F Ratio Gauge, Oil Pressure Gauge and voltage.
Old Jul 31, 2005 | 02:32 PM
Autoworks's Avatar
That is the worst install I have ever seen. I use to have 4 gauges in mine, 2 on the pillar and 2 in the stock radio location, but it just seemed like overkill IMO. I sold them all (they were all AC Autotech.) I am going to replace the 2 on the pillar with voltage and something else
Old Jul 31, 2005 | 03:01 PM
migizzel's Avatar
im working on mine im molding them in my center console
Old Jul 31, 2005 | 03:26 PM
Bunger's Avatar
Default Re: What's with all the gauges? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Not when they serve a purpose.
And I also like coolant temp gauges, because the stock gauge will stay at the same point, when the temp is either 130f or 220f, it always stays the same. And when you try to do things to help your engine temp stay down, an aftermarket gauge is a must.</TD></TR></TABLE>
Agreed, guages can be of great use to better see whats going on with your engine. They can help prevent costly rebuils also.
Old Aug 1, 2005 | 11:13 AM
EJ8chu's Avatar
yeah the gauges are useful to the most important PASSENGER....how about unless u have boost all u need is gas, RPM, Speedo, and temp
Old Aug 1, 2005 | 01:01 PM
northkai3's Avatar
Default Re: What's with all the gauges? (xxsteve803xx)
well actually the gauge is quite functional if u look at the way the gauge is placed in the dash its turned clockwise about 1/4 and when ur driving all u shoud see is the needle pointing straight out if not u know something isnt right. Ive sen them used mostly in autocross
Old Aug 1, 2005 | 01:05 PM
I_eat_Rice's Avatar
Default Re: What's with all the gauges? (northkai3)
Ive got an hourmeter just to see how long the b18 I just put in is actually going to last, also a oil pressure guage and a better temperature guage, but that guage is pretty wierd if they would install it correctly instead of screwing up the dash it might be a little better. but only a little!
Old Aug 1, 2005 | 03:28 PM
ripperbone's Avatar
i have a three pillar pod with autometer gauges in my crx
pretty easy to hook up.
a/f hooked up to wire on the o2 sensor.
oil presure just hooks up to sender
and volt meter hooks up to power & ign
Old Aug 1, 2005 | 04:17 PM
wrXtian's Avatar
guages attract thieves
Old Aug 1, 2005 | 04:18 PM
Default Re: What's with all the gauges? (D16A6_HF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF &raquo;</TD></TR><TR><TD CLASS="quote">guages attract thieves </TD></TR></TABLE>
And a 12 gauge makes them think twice, and if there stupid enough, a 12 gauge will end there thinking all together
Old Aug 1, 2005 | 04:23 PM
wrXtian's Avatar
a 12 gauge will end there thinking all together</TD></TR></TABLE>
their
Old Aug 1, 2005 | 04:24 PM
LMAO^^^
maybe i will buy that sawed off and load up some papershot for the shells to keep under my seat.
their </TD></TR></TABLE>
Yeah yeah, spelling ****
Old Aug 1, 2005 | 07:09 PM
Driven's Avatar
https://honda-tech.com/zerothread?id=1132494
sshh
Sep 12, 2010 11:34 AM
RedneckRicer
Jul 2, 2008 11:51 AM
140sx
Honda S2000
33
Jun 1, 2008 07:56 PM
Driven
22
Mar 7, 2006 07:05 PM
rob42386
14
Mar 28, 2005 10:27 PM
