eg si, b18c1 engine swap question wiring question (knock sensor)
is there a wire i can switch to d3 at the ecu and then hook up the knock sensor wire from the engine harness at the shock tower ?? (so i don't have to run any extra wires into the car) if so can you let me know which pin location i can rob at the ecu? i don't have anyextra pins to stick into the d3 position.
toolowsol
Aug 4, 2003 06:01 AM
