ACT clutch on boost
Old Jul 30, 2005 | 08:28 PM
eK9aT10pSi's Avatar
Default ACT clutch on boost
Scenario: put in a act xtreme clutch kit with a new flywheel & axles from honda. installed everything, bled it til the fluid was clear, turned it on and the pedal feels like its grabbing real close to the firewall. after breaking it in for 500 miles, turned up the boost and the odd part is that when the boost builds and i do a readline pull, it feels as if the clutch pedal is sucking itself back in. ive cehcked around the pedal area for any signs of fluid leakage but none. im wondering should i adjust the clutch pedal to extend its travel so it grabs more up top or is the slave cylinder going bad? TIA
Old Jul 30, 2005 | 08:51 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: ACT clutch on boost (eK9aT10pSi)
is there any leaks around the slave cylinder
Old Jul 30, 2005 | 08:58 PM
eK9aT10pSi's Avatar
Default Re: ACT clutch on boost (street dreams)
nope, i dont see any leaks around the slave cyl. i also tried bleeding it by hand instead of using a pump and same issue. no air comes out so i know its bled well.
Old Jul 31, 2005 | 09:34 PM
eK9aT10pSi's Avatar
bump...
Old Jul 31, 2005 | 10:03 PM
nocturnaldragon's Avatar
After a while the act clutch loses some of its resistance on the pedal, mine did the same thing after the breake in period. I figured its due to the springs losing a bit of tension after wearing in. been the same ever since still more effort then stock tho.
Old Aug 1, 2005 | 09:13 PM
eK9aT10pSi's Avatar
Default Re: ACT clutch on boost (nocturnaldragon)
its only been like 3k miles. i know that wear and tear but not for the pedal engagement to act up.
Old Aug 5, 2005 | 07:59 PM
eK9aT10pSi's Avatar
bump
firecatf7333
Dec 28, 2017 08:14 AM
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
hannslebo
Mar 24, 2009 01:53 PM
Lb1atx
Sep 7, 2007 05:16 AM
Sinner
Sep 13, 2005 08:27 AM
