ES shifter bushing w/ stock/short shifter
Old Jul 30, 2005 | 06:15 PM
amej8's Avatar
Default ES shifter bushing w/ stock/short shifter
just a quick question. but before I start I want to remind everyone (just in case) that this is just a 2 piece bushing kit that installs to shifter linkage and under the shifter (i believe)
anyways, was planning on buying the Energy Suspension Shifter Stabilizer Bushing Kit and was wondering when I put it on my stock shifter, will a B&M short shifter install correctly? I know it's a stupid question but I just wanted to make sure. will I still be able to put the short shifter on without any modifications?
and I was also wondering if there is any noticeable difference with putting the Energy Suspension Shifter Stabilizer Bushing Kit on a stock linkage. I have no modifications done to tranny or shifter. everything is completely stock. I'm eventually getting a B&M short throw (why? cuz they're one of the most commonly liked short shifters I read about) so if there isn't a difference, will I notice it with a short shifter?
thx h-t
Modified by amej8 at 8:16 AM 7/31/2005
Old Jul 30, 2005 | 06:51 PM
krisjk2's Avatar
Default Re: ES shifter bushing w/ stock/short shifter (amej8)
https://honda-tech.com/zerothread?id=1007935
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">BTW, I also have Energy Suspension shifter bushings installed. Makes it even better for shifting.
I also have write-ups on the Energy Suspension bushings install if you Search under my name.</TD></TR></TABLE>
look at the bottom, that guy has the exact same thing you are trying to do. and he has made 2 write ups about it so it works.
Old Jul 30, 2005 | 06:52 PM
amej8's Avatar
Old Jul 31, 2005 | 07:00 AM
d15nonvtec's Avatar
it wont matter what shifter you use, with the bushings. where the bushings are the stock shifter and the b&m shifter are the same
Old Jul 31, 2005 | 09:02 AM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: ES shifter bushing w/ stock/short shifter (d15nonvtec)
^ werd
Old Jul 31, 2005 | 09:57 AM
SpydiR's Avatar
Default Re: ES shifter bushing w/ stock/short shifter (BrokeAssPinoy)
I've got ES bushings on my B&M shifter [thanks evasive ] and my dad has ES bushings on his stock shifter. both work beautifully, and installation is identical.
Boostn B20
Jul 12, 2011 07:35 PM
trackintegra99
May 28, 2008 07:00 AM
jromulo
Jun 2, 2005 12:43 PM
