need help real bad
Old Jul 30, 2005 | 05:09 PM
cutt's Avatar
Default need help real bad
the other day my car started acting funny. have not changed any mods in a long time. been running the same set up for just over a year.
first thing is --- the other day I got into to my car let it warm up for about 3-5 mins go down the street, get to the first stop sign and push the clutch in and the brake and my car stalled. started it back up and everything was fine for the next couple of days.
second thing --- get off work the other night and let my car warm up 3-5 mins, start driving and I notice a slight hesitation between 2000 - 3500 rpm gose away after about 5 mins of light freeway driving ( not boosting )
third thing --- same thing get off work the other night and it was hesatating again so I looked at my E manage and the active L.E.D. was flashing orange not green as usual. (not the interaction L.E.D. ) So then after a couple of mins of driving everyting was fine again untill I pull up to the first red light and push the clutch in and it wants to stall but It didn't.
after that everything was fine again, untill today let my car warm up first 2 or 3 stops it stalled.
I think the problems are conected but not sure, or dont know what it could be
heres my setup: d16z6 8.5:1
e-manage tuned a year ago
p28 ecu
t3t4 10psi
270cc injectors 70% duty cycle
msd wires iriddum plugs
cable clutch act disc and presure plate
thanks for any help
Old Jul 30, 2005 | 05:38 PM
cutt's Avatar
Default Re: need help real bad (cutt)
bump
Old Jul 30, 2005 | 08:09 PM
cutt's Avatar
anyone????????????
Old Jul 31, 2005 | 05:43 AM
sik96teg's Avatar
i had a similar prob still have other issues but mine was i had a small coolant leak from the hose on the connecting pipe never noticed any colant at first but since i fixed that the rpms stopped dropping/engine stalling when i hit the clutch. Friend of mine had a similar prob but his was due to timing.
Old Jul 31, 2005 | 09:31 AM
cutt's Avatar
Default Re: need help real bad (sik96teg)
thanks. anyone else have any ideas
Old Jul 31, 2005 | 11:56 AM
cutt's Avatar
my rad is still full of coolent
Old Jul 31, 2005 | 04:05 PM
sik96teg's Avatar
close to noone is going to reply i had the same exact prob a few monthes ago noone knew anything. One thing for sure i did a valve adjustment and that helped alot it stopped stalling but rpms still dropped when i came to a stop and pressed in the clutch. So then i chacked my tps it was fine and pulled off my iacv and clean it that helped too.
Old Jul 31, 2005 | 07:32 PM
cutt's Avatar
thanks again
Old Aug 4, 2005 | 04:14 AM
sik96teg's Avatar
You figure out the prob yet bro
DOHCIVIC
Classic Hondas
10
Aug 22, 2011 03:02 PM
yayizzil
25
Dec 19, 2008 09:56 AM
Infamous_Imports
Feb 19, 2004 06:21 PM
Confuc1ous
Sep 6, 2003 05:13 AM
spd18
Feb 25, 2003 04:59 PM
