H22 intake manifold....whats good...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junkiii EJ8 »</TD></TR><TR><TD CLASS="quote">do they even make intake manifolds for the h motors</TD></TR></TABLE>
Of course they do. Every H-series equipped car Honda ever made had one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">
Of course they do. Every H-series equipped car Honda ever made had one.</TD></TR></TABLE>
Nice
Skunk2 IM, Euro R (oem), Blox may have made one i think.
Nice
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_HATCH »</TD></TR><TR><TD CLASS="quote">
Nice
Skunk2 IM, Euro R (oem), Blox may have made one i think. </TD></TR></TABLE>
Euro R
Nice
Euro R
There are companies, like JG, that make sheet metal manifolds as well. There are also companies that will modify a stock manifold, like Blacktrax. You just need to decide what your power goals are, in what portion of the band you want more oomph, then find the Manifold that will help you get that. Most of the Manifolds (Euro R, Skunk 2, modified stock Mani) will provide peaks at certain points due to their design. The advantage to a sheet metal manifold is that it can be built to meet your specific goals using runner length and plenum size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22slohatch »</TD></TR><TR><TD CLASS="quote">skunk2s da ****!
I have yet to see any reason to believe that the S2's "da ****" on stockish motors or even highly built ones... I have however seen that the Euro R with slight modification does pretty well on stock and built motors.
Pirate
</TD></TR></TABLE>I have yet to see any reason to believe that the S2's "da ****" on stockish motors or even highly built ones... I have however seen that the Euro R with slight modification does pretty well on stock and built motors.
Pirate
I never did a before and after w/ the manifold, but if you compare my setups w/ others you'll notice that I carry power upwards of 8000rpm while very similar setups on the stock manifold only carry power to around 72-7500.
ilikejesus
Jan 6, 2007 06:34 PM
