anybody know what wood to use to make a sub box
Old Feb 19, 2002 | 03:54 PM
balistic CRX's Avatar
Default anybody know what wood to use to make a sub box
im am thinking of make me a single 12 enclosed box and need to know what is the best wood to use, or can i use any kind of wood. plus i need to know what are all the demensions on making the box.
Old Feb 19, 2002 | 04:01 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: anybody know what wood to use to make a sub box (balistic CRX)
Medite or Medium Density Fiberboard.
Old Feb 19, 2002 | 05:09 PM
STK B16's Avatar
3/4 MDF boards...
Old Feb 19, 2002 | 07:05 PM
95CoupinIt's Avatar
3 letters.....MDF (medium density fiberboard)
Old Feb 20, 2002 | 08:32 PM
Default Re: anybody know what wood to use to make a sub box (Teken)
can i just use any kind of wood? how thick does the wood half to be?
Old Feb 21, 2002 | 07:53 PM
Kazmans94cord's Avatar
just like everyone else said ...... 3/4 MDF....good luck man!
Old Feb 22, 2002 | 08:35 AM
Default Re: anybody know what wood to use to make a sub box (kazmans94cord)
im finally done with my 12inch enclosed speaker project. and yes i did use MDF wood. im just in the matter of seeing how its gonna sound. it almost has like 1 FT. of air space.... should that be good enough for my speaker? its 1 FT.1/2 box all around, just to let you guys know.
Old Feb 22, 2002 | 02:34 PM
JimmieD's Avatar
MDf is definitely the best way to build a box. also for everyones who is worried about weight. Local building supply places should be able to supply you with "lightwieght" MDF but at a premium....but if weight is a issue than it is well worth it.
Old Feb 23, 2002 | 02:34 PM
Chris4x4gill2's Avatar
Default Re: anybody know what wood to use to make a sub box (Phil DeVtec)
Another option to the 3/4" stuff is just use 1/2" MDF...I used it for two tens and it sounds great. you didn't say anything about what you wanted to put in it but check the box it came in to find how big the ernclosure should be and then make your dimensions to fit the space you want to put it in and the totla volume recommended for the sub. I used wood glue and screws to hold it together and silicone on all of the joints to make it airtight. Hope that helps
mikeycivic
Audio / Security / Video
Feb 4, 2010 06:09 PM
crazyboy
17
Nov 2, 2009 08:45 AM
CrazyModGSR
Jul 15, 2004 08:21 PM
initialvtec
19
May 29, 2004 06:51 PM
loki2323
Dec 18, 2002 09:09 AM
