Car got towed....clutch problems?
Old Jul 30, 2005 | 03:55 PM
tankdogg08's Avatar
Default Car got towed....clutch problems?
the other day my integra got towed.....its lowered almost all the way on ground controls with kyb agxs.....and after i got the car out of the impound....my clutch was acting weird....it was engaging right from the floor...so i thought that was weird...then the next day i get in my car and i push the clutch in and there was no pressure...i couldnt get my car to go in gear at all....after playing with the pedal a bit i managed to get it in gear, now sometimes it acts up like that and sometimes it doesnt...and suggestions?
Old Jul 30, 2005 | 03:57 PM
veggiemaster's Avatar
Default Re: Car got towed....clutch problems? (tankdogg08)
is it a hydro or cable?
Old Jul 30, 2005 | 04:01 PM
Finger Lickin' good's Avatar
Default Re: Car got towed....clutch problems? (veggiemaster)
flat bed? or what.
if you car got towed with the front wheels spinning in reverse, with it in gear, that might have messed some stuff up.
stanson's Avatar
it could possibly be a loose bearing or some sort. either way, you migh have to open up the transmission so you might as well upgrade to a stg2 or 3
Old Jul 30, 2005 | 09:39 PM
MugenDC4's Avatar
too bad you didn't notice it when you got the car back from the impound. You could have said they cause the damage and the Towing company are liable. I talk to the tow truck people and if anything happens like cracked bumper or new scrapes they would have to fix it. But I dont know in your situation because its kind of hard to prove its thier fault
Old Jul 31, 2005 | 12:17 AM
ef_you_once_more's Avatar
check your master clutch cylinder before you open the tranny. check your clutch pedal where it meets the firewall and see if there are any leaks
TypeRMonster
Aug 17, 2009 06:08 AM
jester
14
Apr 21, 2005 04:18 AM
91civicEX
Jan 14, 2004 12:17 PM
[626]95-GSR
Feb 15, 2002 02:52 AM
Mr. Softee
Nov 27, 2001 11:36 PM
