need some help!!! (Ej8! WTF!)
Old Jul 30, 2005 | 03:40 PM
sd.coupe's Avatar
Default need some help!!! (Ej8! WTF!)
was going out to change my intake from stock to just a normal short ram intake, and this is what i ran into... help please
I unpluged this connector becuase it's part of the factory intake stsyem..... then i plugged it back in and now my check eng. light wont go off...?!!! doesnt run any different... wtf did i do?... ( 2000 civic ex coupe )
Old Jul 30, 2005 | 03:54 PM
Reid's Avatar
Global Moderator
Default Re: need some help!!! (sd.coupe)
Unplugging and plugging that sensor back in with the car off will not cause a CEL.
Did you connect your IAT?
Old Jul 30, 2005 | 03:55 PM
melissas_man2004's Avatar
most hondas have a back up fuse if not disconnect the battery for 30 min. and what that thing is it is a mass airflow sensor or something to that effect.
Old Jul 30, 2005 | 03:58 PM
sd.coupe's Avatar
yea just stopped by honda.. they said dissconect my alarm and dissconnect my batt for 30mins.. and the light should go offf.... now time to find the alarm thingy. haha
Old Jul 30, 2005 | 04:00 PM
HCivExoo's Avatar
Default Re: need some help!!! (melissas_man2004)
MAP sensor Manifold Absilute Pressure sensor it measures the pressure or amount of vacume in the intake manifold
Old Jul 30, 2005 | 04:02 PM
sd.coupe's Avatar
so wtf... how do i get to bypass that so i can have a normal intake stsyem, not factory that **** is wack.
Old Jul 30, 2005 | 04:09 PM
pdiggitydogg's Avatar
remove the battery's neg cable for like 30seconds - pop it back on. CEL should be gone
You did check the cel though, right?
Old Jul 30, 2005 | 04:16 PM
sd.coupe's Avatar
Default Re: (pdiggitydogg)
CEL?.. HAHA
Old Jul 30, 2005 | 04:18 PM
JDM-97CX's Avatar
That is a Mass Air Flow sensor, just put your intake on, don't try to bypass that because it is one of the main controlling factors of fuel trim. Leave that sensor alone and put your intake on, there is no reason why you should have to remove that to put an intake on.
Old Jul 30, 2005 | 04:33 PM
sd.coupe's Avatar
Default Re: (JDM-97CX)
look at the pics... the wires go down and its connected to the intake tube.
Old Jul 30, 2005 | 04:34 PM
99blackcivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">That is a Mass Air Flow sensor, just put your intake on, don't try to bypass that because it is one of the main controlling factors of fuel trim. Leave that sensor alone and put your intake on, there is no reason why you should have to remove that to put an intake on.</TD></TR></TABLE>
its not a mass air flow sensor, its a MAP sensor
Old Jul 30, 2005 | 04:35 PM
JDM-97CX's Avatar
Default Re: (sd.coupe)
Im pretty sure that the plug in the tube is your IAT, if you buy an intake that is MADE for YOUR car and not some auto zone **** then it should have that plug.
Old Jul 30, 2005 | 04:36 PM
JDM-97CX's Avatar
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">its not a mass air flow sensor, its a MAP sensor </TD></TR></TABLE>
Why would there be a map sensor on the throttle body? The only vacuum that can be measured there is ported vacuum, i.e. when the throttle plate is barley open. After that there is none.
EDIT: I just looked it up and I guess it is a MAP sensor, very odd placement of it though.
Old Jul 30, 2005 | 05:13 PM
Civic4less's Avatar
After you install an intake you have to "reset" your ECU so it can recognize the increased amount of airflow (or decrease). Simply disconnect your battery cable for a few seconds or minutes whatever u want then reconnect it and you're good to go. No CEL (Check-Engine-Light).
Old Jul 30, 2005 | 05:26 PM
sd.coupe's Avatar
Default Re: (Civic4less)
ok so what your saying isssss..... if i buy a intake for my year civic and everything it should have the extra little plug for the map senors?.. becuase it is connected to the pipping of the intake on the factory setup.
Old Jul 30, 2005 | 05:29 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote">so wtf... how do i get to bypass that so i can have a normal intake stsyem, not factory that **** is wack. </TD></TR></TABLE>
You cannot bypass the MAP sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote">CEL?.. HAHA</TD></TR></TABLE>
CEL = check engine light
Hondas use map sensors, not mass air flow sensors.
Do not even bother posting in threads to give advice. You only further the spread of misinformation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote"> look at the pics... the wires go down and its connected to the intake tube. </TD></TR></TABLE>
The harness going to the MAP sensor has two wires branching off of it (the red and green wires). Those wires connect to a sensor in the intake pipe which is called the IAT (Intake Air Temperature) sensor. Make sure both of these sensors are plugged in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">Why would there be a map sensor on the throttle body? The only vacuum that can be measured there is ported vacuum, i.e. when the throttle plate is barley open. After that there is none.
EDIT: I just looked it up and I guess it is a MAP sensor, very odd placement of it though.</TD></TR></TABLE>
All Hondas with OBD systems have MAP sensors on the throttle body.
This just shows you how ignorant you are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4less &raquo;</TD></TR><TR><TD CLASS="quote">After you install an intake you have to "reset" your ECU so it can recognize the increased amount of airflow (or decrease). Simply disconnect your battery cable for a few seconds or minutes whatever u want then reconnect it and you're good to go. No CEL (Check-Engine-Light). </TD></TR></TABLE>
If one does not reset the ECU, it will not throw a CEL.
Use this FAQ if you're not familiar with how to pull CEL codes.
Old Jul 30, 2005 | 05:30 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote">ok so what your saying isssss..... if i buy a intake for my year civic and everything it should have the extra little plug for the map senors?.. becuase it is connected to the pipping of the intake on the factory setup.</TD></TR></TABLE>
They're talking about the hole in the intake for the IAT sensor. Read my above post, and let me know if you have any more questions.
If your intake does not have a hole for an IAT sensor, simply drill a hole in the pipe.
Old Jul 30, 2005 | 05:40 PM
sd.coupe's Avatar
Default Re: (Reid)
wtf... drill a hole and ****... i dont want to do that hahaha, i guess i'll just go waste my money on some intake that has the right "holes" or whatever and gain my 1hp.
Old Jul 30, 2005 | 05:50 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote">wtf... drill a hole and ****... i dont want to do that hahaha, i guess i'll just go waste my money on some intake that has the right "holes" or whatever and gain my 1hp. </TD></TR></TABLE>
Is your IAT not connected?
BTW, don't be afraid to drill the hole. If you're too hopeless, maybe you know someone who isn't as hopeless.
Old Jul 30, 2005 | 05:57 PM
sd.coupe's Avatar
Default Re: (Reid)
yes its connected.
no i dont want to dril.
wouldnt say hopeless.
just want everything to be done the right way.
Old Jul 30, 2005 | 07:23 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd.coupe &raquo;</TD></TR><TR><TD CLASS="quote">yes its connected.
just want everything to be done the right way. </TD></TR></TABLE>
You're clearly have little to no experience.
Please let me clarify that drilling your intake pipe is not "ghetto" by any means. It's simply a case of modifying parts to make it work on your setup.
There is nothing wrong or incorrect about drilling the pipe. I would not have suggested doing so, if there was.
Old Jul 30, 2005 | 08:46 PM
Bond's Avatar
Default Re: (Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
There is nothing wrong or incorrect about drilling the pipe. I would not have suggested doing so, if there was.</TD></TR></TABLE>
Damn right. Don't be say shy to get up and drill that damn hole. It really isn't that hard. All vtec D16's have that. My D16Z6 has it and it's just the map sensor. I don't understand why you would have to drill a hole for it??? It does not take reading's from the anywhere else then the throttle body it's self. That must be the IAT is what need's to be plugged into your new intake. What brand is it??? The AEM intake that I have is universal for all civic's from 92-99. If you just don't have the hole then find out the size and drill it. If you can't do that then go to a mechanics and tell them to drill it. I am pretty confident that they will be able to figure it out .
Old Jul 30, 2005 | 09:31 PM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: (Reid)
Use this FAQ if you're not familiar with how to pull CEL codes.</TD></TR></TABLE>
Its obd2 the good ol' trick wouldnt work for him.
Honestly he could just leave the sensor plugged in, n let it hang not connected the the intake at all, then reset the ecu n the cel would go off n not come back on.
Just a suggestion tho, your intake must be cheap as hell... ractive maybe, it will prob end up rusting out in about 8 months so dont sweat your .5 hp, u only got a y8 anyway the only thing the intake does is make vtec a little louder.
Good ol' Screwtape's Avatar
Multi-paradigm
Default Re: (Reid)
You cannot bypass the MAP sensors
/thread
Old Jul 30, 2005 | 10:20 PM
Reid's Avatar
Global Moderator
Default Re: (EJ8VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Its obd2 the good ol' trick wouldnt work for him.</TD></TR></TABLE>
OBD2 cars can have codes pulled from them in the same way that OBD1 cars can.
