94 Si HB Ls Vtec tranny ?
i have a lsvtec with a gsr tranny im usin the ls half shaft with the ls axle on the driver side what axle i need for the passenger side i used an ls but when i drive the car pulls hard to the left could this be the axle???????????????
you are going to use any b-series axle they are all the same. but you may want to try getting an alignment any time you bust a ball joint you are suppose to get get it aligned
