what to do about friend hydro locked car
Old Jul 30, 2005 | 02:12 PM
dc28012's Avatar
Default what to do about friend hydro locked car
just as the topic stated. friend hydro locked car. how would he fix it? opened the throttle and a intake full of water came flowing out. the car doesnt turn over. took of the valve cover but didnt see any water there. what to do? is the moter pretty much gone?
Old Jul 30, 2005 | 02:29 PM
yellow blur's Avatar
Default Re: what to do about friend hydro locked car (dc28012)
Purdy much. How long did he run the motor after he sucked in water? Check the spark plug cavity, water in there?
Old Jul 30, 2005 | 03:24 PM
ZygSpeed's Avatar
Rotate the motor with the spark plugs out, then I'd try a compression followed by a leakdown test.
Good luck.
Old Jul 30, 2005 | 04:51 PM
01usjdmr's Avatar
It will usually have a bent # 1 rod. It really depends on alot of things.
Old Jul 30, 2005 | 05:03 PM
TeayotaSoupra's Avatar
Default Re: what to do about friend hydro locked car (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Rotate the motor with the spark plugs out, then I'd try a compression followed by a leakdown test.
Good luck. </TD></TR></TABLE>
what he said. when you "Start" it with the plugs out it should shoot the water out as long as he hasn't been trying to crank it over again and again.
Old Jul 30, 2005 | 05:09 PM
Reid's Avatar
Global Moderator
Default Re: what to do about friend hydro locked car (TeayotaSoupra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeayotaSoupra &raquo;</TD></TR><TR><TD CLASS="quote">what he said. when you "Start" it with the plugs out it should shoot the water out as long as he hasn't been trying to crank it over again and again.</TD></TR></TABLE>
What difference would it make if he was trying to crank it over and over again?
So long as the rings aren't frozen in the cylinders, water will shoot out of the plug holes.
Old Jul 30, 2005 | 05:34 PM
P95's Avatar
P95
Default Re: what to do about friend hydro locked car (Reid)
can u make an attachment and vacuum the water out through the spark plug hole?
Old Jul 30, 2005 | 05:40 PM
Reid's Avatar
Global Moderator
Default Re: what to do about friend hydro locked car (P95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P95 &raquo;</TD></TR><TR><TD CLASS="quote">can u make an attachment and vacuum the water out through the spark plug hole?</TD></TR></TABLE>
One could, but it'd be a waste of time.
The majority of the water will be shot out of the combustion chamber when the engine is cranked over a few times.
Old Jul 30, 2005 | 06:34 PM
ITR9's Avatar
that sucks...
*/me fears when it rains with his AEM intake..*
Old Jul 30, 2005 | 07:18 PM
ZygSpeed's Avatar
Default Re: (ITR9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR9 &raquo;</TD></TR><TR><TD CLASS="quote">*/me fears when it rains with his AEM intake..*</TD></TR></TABLE>
Rain is not a big problem, just stay out of puddles that go half way up the wheel and other substantial flooding.
When in doubt and if at all possible you can always disconnedt the intake at the TB/IM just so you don't suck up the big stuff on the way home.
Old Jul 30, 2005 | 07:33 PM
Finland's Avatar
New rods at the minimum, good luck.
Old Jul 30, 2005 | 08:14 PM
Bbasso's Avatar
Default Re: what to do about friend hydro locked car (yellow blur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur &raquo;</TD></TR><TR><TD CLASS="quote">the spark plug cavity</TD></TR></TABLE>
First time ever hearing that term... I thought it was called a combustion chamber
As for sucking water thru the AEM CAI... that must have been one hell of a lake!
5, Five years and never had a problem with mine.
as for getting the water out... take out plugs disconnect distrib and crank til it's dry. Pray you did not do any damage to the rods or worse.
Old Jul 30, 2005 | 09:07 PM
ZygSpeed's Avatar
Default Re: what to do about friend hydro locked car (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">First time ever hearing that term... I thought it was called a combustion chamber ...</TD></TR></TABLE>
Combustion chamber is where combustion happens, "spark plug cavity" would be where the "spark plug" goes.
Old Jul 31, 2005 | 07:19 AM
01usjdmr's Avatar
[QUOTE=Bbasso]
It happens down here in FL alot. AEM makes us alot of $$$.
Old Jul 31, 2005 | 08:06 AM
nsxtasy's Avatar
H-T Order of Merit
If he treats your car this way, he is not your "friend".
Take it to the best mechanic in your area to get it fixed. After all, your "friend" is going to pay for the repair, right?
Old Jul 31, 2005 | 12:23 PM
Utilitarian's Avatar
Default Re: what to do about friend hydro locked car (01usjdmr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01usjdmr &raquo;</TD></TR><TR><TD CLASS="quote">[QUOTE=Bbasso]
It happens down here in FL alot. AEM makes us alot of $$$. </TD></TR></TABLE>
I take it you're a mechanic?
Old Aug 1, 2005 | 05:51 AM
Dave_B's Avatar
Wait I'm in FL and I never have a problem. If you use a little common sense you won't have a problem. If your an idiot then hey that's gonna cost you. Worst case scenario, push in the clutch or shut the car off when your about to hit a big puddle. I don't see what the deal is with people being scared with a CAI.
Old Aug 1, 2005 | 01:14 PM
mikestypeRR's Avatar
Rebuild ... Stronger... Bigger... Better... Faster.
Old Aug 1, 2005 | 05:03 PM
01usjdmr's Avatar
Default Re: (Dave_B)
We just put a used engine in a gsr last week for a doctor. If you live where it floods alot when it rains it will happen. There isn't much you can do about it sometimes. The doctor said hell with this and bought a full factory intake system for his car. Yes, I have worked for a Honda/Acura dealer for ten years now.
luder23
Dec 14, 2012 06:07 AM
oneprelude
Nov 30, 2008 05:45 PM
Draggin99Si
21
May 29, 2005 10:07 AM
StatGSR
Jun 9, 2004 03:49 AM
wuhungsixxx
Jul 17, 2001 12:17 PM
