what does the pcv valve do and can it be removed ?
Old Jul 30, 2005 | 02:02 PM
EK FLY's Avatar
Default what does the pcv valve do and can it be removed ?
what would you need to remove this bitch off the engine and would I want to remove ?
Old Jul 30, 2005 | 07:38 PM
vuuspec's Avatar
Default Re: what does the pcv valve do and can it be removed ? (EGSR)
it allows gas from the crankcase to be sucked into the intake manifold to be burned. why do you want to remove it? it helps with emissions and fuel economy. i dont see any negatives to keeping it
Old Jul 30, 2005 | 07:43 PM
boostedcivicsir's Avatar
Mr. Badwrench
what does the pcv valve do?
PCV- positive crankcase ventilation
it allows the crank case pressure created by the reciprocating assembly to be evacuated by way of manifold vacuum
can it be removed ?
no it will cause premature ring failure and other issues.
what would you need to remove this bitch off the engine? and would I want to remove ?
to answer the second half of the question, NO
there is a very good reason it is there and without it, your engine is in for a world of hurt. some racers do remove then BUT they instead use a reed valve and use the outgoing exhaust to create a venturi effect to remove the crankcase gasses.
Old Jul 30, 2005 | 09:04 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: what does the pcv valve do and can it be removed ? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">what does the pcv valve do?
can it be removed ?
there is a very good reason it is there and without it, your engine is in for a world of hurt. some racers do remove then BUT they instead use a reed valve and use the outgoing exhaust to create a venturi effect to remove the crankcase gasses.</TD></TR></TABLE>
dam u really answer this question
Old Jul 30, 2005 | 10:14 PM
Mashimaro's Avatar
you can also route an oil catch can in between the PCV and the intake manifold. keeps the oil blowby from going back into your intake and lowering your octane level.
Dekorum
21
Oct 14, 2013 05:08 AM
JDM95lude
Oct 14, 2006 08:21 AM
b16bhatch
Nov 18, 2005 12:16 PM
