About my new axle??
Old Jul 29, 2005 | 08:29 PM
nusdogg's Avatar
Default About my new axle??
I bought a new axle 5 months ago, its on the driver side and its a manual 5 spd with . Everytime i turn left or right, the new axle still click, i wonder what's wrong with it? is not go in all the way or what? anybody have a idea where what could go wrong??
Old Jul 30, 2005 | 10:04 AM
CD7power's Avatar
Default Re: About my new axle?? (nusdogg)
did you check if the boots torn?
Old Jul 31, 2005 | 01:46 AM
deserthonda's Avatar
if you replaced it 5 month ago and the noise is starting now i am sure it went in all the way otherwise you would have had problem long before this ..........you might have a bad axle again make sure which side is noisy if it is the same exchange it should still be under warranty
Old Jul 31, 2005 | 04:03 AM
P_Adams's Avatar
Default Re: About my new axle?? (deserthonda)
Agreed. In actuality those "New" axles that are offered are often "Remanufactured" (Used but reconditioned). Sometimes things can go horribly wrong. The only thing that might bugger up your replacement under warranty request is if the cv joint boot is torn. If it's intact, you should be home (almost) free !!!
P
ShinotakuX
26
Oct 18, 2008 06:38 PM
213374U
May 28, 2007 08:38 PM
o VALTER o
May 23, 2007 02:05 PM
DC2SIR-G
Feb 26, 2006 06:13 PM
sinfulDB1
Dec 2, 2003 10:53 AM
