obd2 b18c1 in obd1 eg?
Old Jul 29, 2005 | 07:50 PM
cthan3o3's Avatar
Default obd2 b18c1 in obd1 eg?
i just wanna know what parts i need to convert an obd2 gsr motor into obd1. anything like alternator, injectors, etc? and which engine harness will i need to use? the d16z6 one or the obd2 b18c1?
Old Jul 29, 2005 | 07:55 PM
Luserkid's Avatar
Default Re: obd2 b18c1 in obd1 eg? (cthan3o3)
How good are you at rewiring? You could rewire your whole harness into obd2 from OBD1. But i wouldnt even do that to much work.
Simple way out:
Alternator - Get an obd1 B series
Wiring harness - any obd1 wiring harness
Dist. - OBD1 B series VTEC
Injectors - obd1 or rewire your obd2 injector clips to your obd1 harness (easy)
Congrates now your obd1.
Old Jul 29, 2005 | 08:04 PM
cthan3o3's Avatar
Default Re: obd2 b18c1 in obd1 eg? (Luserkid)
cool thanks a lot! if i got an obd1 p72 is it just plug and play or would i have to rewire it for something else like knock sensor, iab, etc?
Old Jul 29, 2005 | 08:07 PM
Luserkid's Avatar
I dont know, what trim and year is your car? You might not have to wire all that stuff in if you have the correct trim.
Old Jul 29, 2005 | 08:55 PM
cthan3o3's Avatar
i have a 95 civic ex, the engine is a 99 gsr motor.
Old Jul 29, 2005 | 08:58 PM
jetpilot's Avatar
If you have the 99gsr wiring harness just use the alternator plug and distributor plugs on your civic harness and it should work fine
Also use your stock civic injectors
Old Jul 29, 2005 | 09:26 PM
Luserkid's Avatar
All youll need to wire up the knock sensor and thats a wire straight to C3
Old Jul 29, 2005 | 09:29 PM
Reid's Avatar
Global Moderator
Just use the OBD2 GSR engine harness and an OBD1 ECU.
Everything will work fine.
The above suggestions are far more costly.
Old Jul 29, 2005 | 09:42 PM
cthan3o3's Avatar
Default Re: obd2 b18c1 in obd1 eg? (Reid)
so the obd2 gsr harness should plug into everything ok in my 95 civic?
Old Jul 30, 2005 | 04:30 AM
deez92's Avatar
yes
Old Jul 30, 2005 | 05:22 AM
jetpilot's Avatar
the Obd2 harness on integras and some civics have the shock tower plugs (I think ALL tegs have this but not ALL civics)
The plugs are all the same either OBD1 or OBD2
then chip your ecu and add a b18c map (copy and paste in crome)
Old Jul 30, 2005 | 06:26 AM
94GSRCivic's Avatar
I know somebody that had the same setup and his worked after adding his vtec wires into his ECU. It MIGHT work, but dont quote me.
Old Jul 30, 2005 | 05:16 PM
Reid's Avatar
Global Moderator
Default Re: (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94GSRCivic &raquo;</TD></TR><TR><TD CLASS="quote">I know somebody that had the same setup and his worked after adding his vtec wires into his ECU. It MIGHT work, but dont quote me.</TD></TR></TABLE>
A car that had a D16Z6 is obviously wired for VTEC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot &raquo;</TD></TR><TR><TD CLASS="quote">the Obd2 harness on integras and some civics have the shock tower plugs (I think ALL tegs have this but not ALL civics)
then chip your ecu and add a b18c map (copy and paste in crome)</TD></TR></TABLE>
If you knew this before, why did you suggest hacking up two perfectly good engine harnesses?
Old Jul 31, 2005 | 08:27 AM
jetpilot's Avatar
I forgot I guess, sorry about that
mindless4banger
Engine Management and Tuning
Feb 28, 2016 12:50 PM
efrunner09
10
Sep 21, 2009 02:57 PM
NOman0608
Jul 26, 2007 10:28 AM
civtegra_hybrid
Sep 14, 2004 01:29 AM
mjrage
Jun 24, 2004 09:53 AM
