Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Pace truck brakes
Old Feb 19, 2002 | 02:18 PM
Grumpy's Avatar
New User
Default Pace truck brakes
http://www.imagestation.com/picture/...6/fdec329c.jpg
http://www.imagestation.com/picture/...2/fdec32fb.jpg
http://www.imagestation.com/picture/...7/fdec322f.jpg
http://www.imagestation.com/picture/...0/fdec319f.jpg
Good till the last drop.
[Modified by Grumpy, 11:26 PM 2/19/2002]
Old Feb 19, 2002 | 02:19 PM
Mike P.'s Avatar
25 Year Member
Default Re: Pace truck brakes (Grumpy)
[obvious]I think it's time for new ones![/obvious]
Old Feb 19, 2002 | 02:23 PM
GrasStrypa's Avatar
And again I felt no difference in braking until the piston popped out and lost all braking capability
Old Feb 19, 2002 | 03:17 PM
WRXRacer111's Avatar
Default Re: Pace truck brakes (George Knighton)
LOL... Honda Pace Truck. Hmm... maybe a lowered MD-X would work?
Old Feb 19, 2002 | 03:23 PM
MaddMatt's Avatar
Default Re: Pace truck brakes (WRXRacer111)
That right there is a worn out brake pad!
I've gone down to the backing plate before, but that's rediculous.
Try driving SLOWER!
Old Feb 19, 2002 | 03:26 PM
smokin rubber's Avatar
Default Re: Pace truck brakes (MaddMatt)
what vehicle was this?
Old Feb 19, 2002 | 03:41 PM
Default Re: Pace truck brakes (smokin rubber)
Tony's Chevy Xtreme pickup/pace car.
Old Feb 20, 2002 | 09:40 AM
cobalt's Avatar
New User
Not much we can do here...not even with the Panther XP. You have to look for ways to improve cooling as much as possible...even spraying water on the rotors and calipers.
Otherwise...larger rotors and calipers...but if you did that to P+'s on the 4500lb truck...you'll do just the same to XP. The XP will last longer and stop better, certainly, but you'll end up with the same result unless you check your pads often and change them when they get too thin.
Andie
Old Feb 20, 2002 | 09:57 AM
Geezer's Avatar
Suggestion for a new rule: Trucks get teched after every session.
Old Feb 20, 2002 | 09:58 AM
Grumpy's Avatar
New User
Default Re: Pace truck brakes (Geezer)
Trucks get teched after each LAP!
Knestis's Avatar
Default Re: Pace truck brakes (CarbotechAndie)
With water-cooled brakes, don't spray water directly on the hot metal bits! These systems work by taking heat energy out of the incoming air by using it to evaporate water injected into the airstream ahead of things that need cooling.
Seems like there must be some stock car parts that would bolt onto the front spindles of Tony's truck...
Kirk
Old Feb 20, 2002 | 10:02 AM
Grumpy's Avatar
New User
In all fairness, the truck was using Carbotech Panther + pads, and it STOPS the truck. The pads were used also at Summit Point for the last event last year. That's four hours of HP driving and whos knows how many hours of pace laps.
This truck should be the poster child for Carbotech.
Next time out, Carbotech XP with air ducts and hopefully water cooling.
Grumpy
Old Feb 20, 2002 | 10:40 AM
Crazydave's Avatar
wow...
have you ever seen a backing plate that "welded" itself to the piston?
Old Feb 20, 2002 | 10:43 AM
Grumpy's Avatar
New User
Default Re: Pace truck brakes (Crazydave)
This one had to be chiseled apart from the piston. The piston was actually rubbing against the rotor. Rotor was cryotreated and is really not that bad.
Old Feb 20, 2002 | 11:15 AM
Crazydave's Avatar
thats a lot of heat...
may you should have had the piston and backing plate and caliper cyro treated
Old Feb 20, 2002 | 11:26 AM
Grumpy's Avatar
New User
I believe all Carbotech backing plates are cryotreated.
Old Feb 20, 2002 | 11:52 AM
cobalt's Avatar
New User
Our backing plates are not crygenically treated...they are industry standard cold rolled steel.
-Andie
Old Feb 20, 2002 | 12:01 PM
krshultz's Avatar
Andie, you just reminded me of something I've been wanting to ask you. Does a water spray actually work?
I would think that at those temperatures, the water would evaporate before it got to contact the rotors at all...or if nothing else, would evaporate so quickly that it wouldn't do much good.
Old Feb 20, 2002 | 12:18 PM
B18CXr's Avatar
Default Re: Pace truck brakes (krshultz)
over seas where they race semi trucks, they use it. so it's gotta work....somehow
Old Feb 20, 2002 | 12:55 PM
Willard's Avatar
Default Re: Pace truck brakes (B18CXr)
no water = trucks loose brakes within one lap
Will
-who likes the truck racing on the OLD Speedvision
Old Feb 20, 2002 | 01:05 PM
4doorH22's Avatar
The mechanism of evaporation is heat energy in the first place. Evaporating a liquid removes thermal energy and cools stuff. That's why we sweat.
monsterb18b
Honda Civic (2001 - 2005)
Aug 31, 2008 07:02 AM
LBBP R
Jan 26, 2008 08:14 AM
RiceRocketDave
Dec 30, 2006 10:32 PM
jdmrealm
Honda Motorcycles
Jul 19, 2002 08:55 AM
ITR0145
Honda Motorcycles
Apr 17, 2002 01:36 PM
