Code 3 MAP Sensor HELP!!!
Old Jul 29, 2005 | 03:14 PM
volvopv544's Avatar
Default Code 3 MAP Sensor HELP!!!
every now and then (more recently) when I drive my car (89 crx si, all stock) it will run fine, then all of a sudden I will hear a couple clicks from the ecu then the cel flicks on, car will bog down or die if I dont keep on the throttle. I have checked all the vac lines and replaced any that were suspect. I just replaced the plugs, plug wires, cap & rotor, gas cap, fuel filter, radiator cap and did the oil, filter and tranny. I have tested the MAP sensor using the procedures in the chiltons manual and it tests fine. Is there something else that can cause this code? I appriciate any help you guys can give me. Thanx Bryan
Modified by volvopv544 at 8:41 PM 7/30/2005
jdmacuraITR
Jul 28, 2014 06:06 AM
miguey310
Jul 7, 2010 01:07 AM
toolbox21
May 8, 2010 09:17 AM
nebulabox
Feb 27, 2010 11:08 AM
