stroker kit for d16z6
Old Jul 29, 2005 | 02:33 PM
lavo81's Avatar
Default stroker kit for d16z6
dose anyone make a stroker kit for a d16z6 and / or is there a cheap way to do it?
Old Jul 29, 2005 | 06:50 PM
d16dcoe45's Avatar
Default Re: stroker kit for d16z6 (lavo81)
The d16 already has a very long stroke (90mm) and a small bore (75mm) stroking it doesn't really make much sense--it will be like a tractor motor!! If you want more displacement your best bet is to have it sleeved to 78mm or 79mm--you will have almost a 1.8. I think one company (a real bad company) had a 94mm stroker--or you could try to fit a d17 crank (94mm) but you will have to modify the crank a bit. Bad idea all around. I suppose it isn't a terrible idea and you are going for a max displacement d--you could sleeve it and stoke it--have 1.9 possibly 2.0 if you could get the bore to 81-82mm!!
Old Jul 29, 2005 | 08:09 PM
-=Zeqs=-'s Avatar
Default Re: stroker kit for d16z6 (d16dcoe45)
Stock bore and stroke according to Helms is 74 mm and 89 mm respectively.
If you look at the VTEC B-series engines, they have 81 mm bores and a stroke that is less then 89 mm. In turn, those engines have a noticably higher redline and respond better to modifications.
I agree with d16dcoe45, if you are dying for more displacement, get your block sleeved and bored out to 78 - 79 mm's. You'll be sitting just under 1800 cc's if you do so.
If you still insist upon going with a stroker block though, R & D Dyno offers stroker setups for the D-series.
Old Jul 30, 2005 | 08:50 AM
lavo81's Avatar
Default Re: stroker kit for d16z6 (-=Zeqs=-)
ok thanks alot guys
Old Jul 30, 2005 | 12:39 PM
d16dcoe45's Avatar
When I said "a real bad company" referring to who made stroker kits for d series motors I wasn't referring to R&D Dyno--I was referring to a company that I can't remember the name of--everybody had problems with this guy. I think Bisi used a 2.0 liter D-series to run the 10.70-10.90(from R&D dyno) before he retired it to go F-series.
Old Jul 30, 2005 | 02:55 PM
lavo81's Avatar
was it n/a or FI?
Old Jul 30, 2005 | 05:10 PM
ALLMOTA92EG's Avatar
bisimoto is all motor only
Old Jul 30, 2005 | 05:30 PM
lavo81's Avatar
Default Re: (jdm92civichb)
ok thanks
Old Aug 4, 2005 | 01:06 PM
-=Zeqs=-'s Avatar
Default Re: (lavo81)
I am inclined to believe that Bisi has had ties with R&D Dyno in the past. Don't know if he still does anymore.
mike93eh2
Aug 3, 2010 10:01 AM
hondapwr
Sep 27, 2008 09:19 AM
94d16zdvtec
Apr 29, 2008 07:24 AM
Zeus Zore
Dec 28, 2002 06:55 PM
