LS/Vtec or GSR in a DA?
im building an all motor setup for my 91 integra and was playin with two different motor setups in my head
I was planin on using the same types of parts in either the LS/Vtc or GSR
eagle rods
ACL bearings
P30 pistons
ITR valve train
skunk2 or toda cams
b16 cable tranny with LSD
75 shot of nitrous
Which would be a better daily driver/ track/ quarter mile motor?
let me know your suggestions, thanks
eagle rods
ACL bearings
P30 pistons
ITR valve train
skunk2 or toda cams
75 shot of nitrous
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9ls-vtec91 »</TD></TR><TR><TD CLASS="quote">im building an all motor setup for my 91 integra and was playin with two different motor setups in my head
eagle rods
ACL bearings
P30 pistons
ITR valve train
skunk2 or toda cams
75 shot of nitrous
Either one is a good choice, i'd go with the ls/vtec for its longer stroke, da's are a little heavy so every bit of power helps out.
eagle rods
ACL bearings
P30 pistons
ITR valve train
skunk2 or toda cams
75 shot of nitrous
</TD></TR></TABLE>Either one is a good choice, i'd go with the ls/vtec for its longer stroke, da's are a little heavy so every bit of power helps out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicgsr19 »</TD></TR><TR><TD CLASS="quote">
Either one is a good choice, i'd go with the ls/vtec for its longer stroke, da's are a little heavy so every bit of power helps out. </TD></TR></TABLE>
That sums it up nicely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 »</TD></TR><TR><TD CLASS="quote">stock gsr w/ 75 shot (direct port progressive injection)
why should i go with a stock motor over a built one? *BUMP*
</TD></TR></TABLE>why should i go with a stock motor over a built one? *BUMP*
im building a LS/VTEC motor right now. im using the GSR head and P30 pistons like u. the compression sation on that is gonna be 11.8:1. i was also gonna run a 75 wet shot on the motor but i was strongly advised not too. if i had forged internals then i woulda sprayed. so right now im selling my nitrous kit.
i say go for a fully built LS/VTEC. u can use LS rods but get ARP rod bolts installed on them. ur gonna have to machine the P30 pistons if u wanna run them eagle rods. slap on a set of SKUNK2 Pr0 1 cams and the motor will be pretty powerful. 190-200 whp can be seen from that setup
My new set-up in the works is:
GSR bottom end with JDM ITR pistons approx 11.5:1
stock rods w/ ARP rod bolts
fully built GSR head
.5 oversized valves
Rocket M22 cams/valvetrain
It should be pushin a little over 200whp
.5 oversized valves
