Manual tranny is loud...
Old Feb 19, 2002 | 01:16 PM
Speed_Ricer99's Avatar
Default Manual tranny is loud...
Somone told me to put gear oil in it insted of regular oil... Will that help take noise away?
What is the capacity of that pan anyway?
Old Feb 19, 2002 | 01:40 PM
88crxoncrack's Avatar
Default Re: Manual tranny is loud... (Speed_Ricer99)
Use NOTHING but HONDA manual transmission fluid / oil. Get it from the dealership. It holds two (2) quarts.
Old Feb 19, 2002 | 02:07 PM
balistic CRX's Avatar
Default Re: Manual tranny is loud... (88crxoncrack)
go and use manual tranny fluid from any auto store. its usually 85-95w, maybe your using a lesser weight oil and thats why its making sounds. it all matters on the weight you put.
[Modified by balistic CRX, 3:07 PM 2/19/2002]
Old Feb 19, 2002 | 03:02 PM
Lt. Dan's Avatar
Default Re: Manual tranny is loud... (balistic CRX)
Hm... that's odd... I could've sworn that Honda MTL was 30 WEIGHT... But hey, what do I know, I just worked on them professionally.....
Dan
Old Feb 19, 2002 | 03:11 PM
Default Re: Manual tranny is loud... (Lt. Dan)
Dan
i put 85-95w im my tranny and it seems pretty quiet.
Old Feb 19, 2002 | 04:27 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
5w-30 is what honda recommends.
Old Feb 19, 2002 | 04:35 PM
Mugen Dom's Avatar
[QUOTE]go and use manual tranny fluid from any auto store. its usually 85-95w, maybe your using a lesser weight oil and thats why its making sounds. it all matters on the weight you put.
[QUOTE] do not use anything but the honda mtf it is wut is meant for ur tranny ive seen bad things happen to peoples trannys when using motor oil and redline crap.
[Modified by jdmB18hatch, 8:36 PM 2/19/2002]
Old Feb 19, 2002 | 04:41 PM
Trinity's Avatar
Default Re: Manual tranny is loud... (jdmB18hatch)
you are not supposed to put gear oil in your car and if you want something beside freaking tranny oil from honda put in 10w-30 motor oil . that is what honda told me to use if i had no other choice but theirs but i would stay with honda's stuff
Old Feb 19, 2002 | 05:49 PM
Blown90hatcH's Avatar
Yeah, drain it out.......put some honey in there......and it will be quit too.
Old Feb 19, 2002 | 08:45 PM
andrew dc's Avatar
exactly.. but per helms 90-91 teg manual.. it is 2.1 quarts wet or 2.2 dry
Old Feb 19, 2002 | 08:47 PM
Mugen Dom's Avatar
Default Re: Manual tranny is loud... (CRX25)
in a b series yes in a d series no a d series takes 1.9 quarts
Old Feb 19, 2002 | 08:53 PM
andrew dc's Avatar
good point.. my bad...
Old Feb 20, 2002 | 12:09 AM
rice_classic's Avatar
Do the quarts really matter? don't you just filled it up until it runs out of the fill plug? btw: I've used 10w-30 castrol gtx in my Tranny in my rex si for about 50k mi. now and it's just as strong and clean and good as it was when I bought it!
I'm glad I read this post it reminds me.. I need to change my tranny fluid!
Old Feb 20, 2002 | 08:10 PM
Gasoline Fumes's Avatar
Default Re: Manual tranny is loud... (rice_classic)
I've never measured the fluid. I only check how much fluid it takes so I know how much to buy.
Old Feb 20, 2002 | 08:34 PM
Default Re: Manual tranny is loud... (Gasoline Fumes)
You guys got me so worked up on this that i'm actually reading books and ****!
MTF Capacities:
EW's - 2.4 qts
ED's - 1.9 qts (4WD - 2.4)
D series - 1.9 qts
B16, B20 - 1.9 qts
B18 (all) - 2.3 qts
CRV Rear diff - 1.1 qts (in case anyone got brave and made a hybrid AWD civic)
It does say that you are simply supposed to fill until it flows out of the fill hole though, so just fill that **** up!
GSR_hatch936
36
Nov 12, 2007 08:53 PM
crxpwr1
14
Mar 17, 2007 12:02 PM
Alibi86
Sep 9, 2005 06:02 AM
yaya
Nov 6, 2003 11:22 AM
LshatchTurbo
Dec 15, 2001 03:34 PM
