h22 in 95 integra?
Hi, I plan on doing a swap in the next 2 months. I have a 95 ls integra. As far as I know there I should get the 92-96 h22's? And also on http://www.hmotorsonline.com, they have one h22 with complete changeover
http://www.hmotorsonline.com/s...30016
and one with just ecu motor and tranny
http://www.hmotorsonline.com/s...30015
Since I am doing the swap, I should go for the one with just the ecu, motor and tranny correct? Thanks.
i would go for the complete swap cause you'll need the shift linkage too, unless you already have that and it comes with axles cause you'll need the prelude inners from the axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingJeff »</TD></TR><TR><TD CLASS="quote">but do we use the shift linkage off the lude?</TD></TR></TABLE>
Yes you use the shift linkage and also the shift assembly.
The complete changeover might be the way to go sence it comes with axles/mid shaft. That way you can run prelude inners and integra 88-89 outers 0r 90-93 outers using the stock h22a halfshaft.
i take it the HUGE thread at the top of the forum that details the swap step by step, and even tells you where harness mods need to be made, what axles to use and hwo to deal with teh fuel line and power steering line was no help.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">i take it the HUGE thread at the top of the forum that details the swap step by step, and even tells you where harness mods need to be made, what axles to use and hwo to deal with teh fuel line and power steering line was no help.....</TD></TR></TABLE>
Lol. I LUV IT!!!!!
Lol. I LUV IT!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KingJeff »</TD></TR><TR><TD CLASS="quote">I heard the 93 accord axles. </TD></TR></TABLE>
86-89 teg axles with the prelude midshaft. You will only need to replace the drivers side inner with a prelude to meet the midshaft.
djSALIX
Nov 21, 2005 10:42 PM
