b16 tranny blown on almost stock si...?
Old Jul 29, 2005 | 10:25 AM
turbosi03's Avatar
Default b16 tranny blown on almost stock si...?
just wondering how this happens? people are using these trannys for 600+hp cars. this guy is alomost stock, I feel he is doing something wrong, especially after he said the replacment one blew also
install? funky driving? anyone know what can cause this?
Old Aug 3, 2005 | 08:25 AM
turbosi03's Avatar
Default Re: b16 tranny blown on almost stock si...? (turbosi03)
I'm gonna throw out a bump... see if I get any love in this misc tech forum
Old Aug 3, 2005 | 07:38 PM
DANG YO's Avatar
same **** happened to my b16 cable tranny a while back. i left a friends house and shifted to second and BLAM that **** was fucked
Old Aug 3, 2005 | 07:39 PM
xEnderx's Avatar
Default Re: b16 tranny blown on almost stock si...? (dc2kid)
I actually siad "Goddamn!!!!" out loud when I saw that tranny case. How on EARTH did that happen?
Old Aug 3, 2005 | 07:52 PM
v4lu3s's Avatar
RTFM
maybe too many high rpm drag style launches?
Old Aug 3, 2005 | 08:08 PM
xEnderx's Avatar
Default Re: (v4lu3s)
You would have to drop it at freaking 8k to even have a chance of doing that.
Old Aug 3, 2005 | 09:04 PM
snowseeker's Avatar
Default Re: (xEnderx)
Where that break is, has nothing to do breaking on a launch. Something else (bearing most likely or spider pin) let loose in the tranny and the diff./ring gear shot it threw the case.
Most broken trannys from launch have cracks from the bearing housings. Now this is cases we are talking about, some trannys broken from launch just eat everything up inside and leaves the case intact.
Old Aug 3, 2005 | 09:23 PM
xEnderx's Avatar
Default Re: (snowseeker)
^^^ Agreed, but why on earth would the bearings jsut let go? Maybe a pin broke....**** I dunno. Either way its pretty messed up.
reminds me of the time I saw a D16Y8 tear a piston loose from a rod at 2000 RPM under maybe 1/3 throttle.
Old Aug 3, 2005 | 09:41 PM
snowseeker's Avatar
Bearing release all kinds of junk in the tranny when they atsrt to go bad. Bearing cages start flying around. Eventually one of the peices takes out a main part of the tranny and all hell breaks lose.
Old Aug 3, 2005 | 11:08 PM
Icey112's Avatar
i blew out 2 diffs. and 1 case on my 99 si tranny .and i was maybe around 165whp at the time.
Old Aug 4, 2005 | 06:59 AM
tgreaves's Avatar
Default Re: b16 tranny blown on almost stock si...? (Icey112)
That looks like the reverse idler shaft hanging out of the tranny..
Old Aug 4, 2005 | 09:49 AM
snowseeker's Avatar
Default Re: b16 tranny blown on almost stock si...? (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">That looks like the reverse idler shaft hanging out of the tranny.. </TD></TR></TABLE>
Shift rod.
Old Aug 4, 2005 | 09:52 AM
tgreaves's Avatar
Default Re: b16 tranny blown on almost stock si...? (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
Shift rod.</TD></TR></TABLE>
Yup.. I saw the hole in the top and that made me think it was the idler shaft.. Wow..
Old Aug 8, 2005 | 01:12 PM
turbosi03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Where that break is, has nothing to do breaking on a launch. Something else (bearing most likely or spider pin) let loose in the tranny and the diff./ring gear shot it threw the case.
Most broken trannys from launch have cracks from the bearing housings. Now this is cases we are talking about, some trannys broken from launch just eat everything up inside and leaves the case intact.</TD></TR></TABLE>
hmm, thats interesing and good to know
still don't understand what action as far as driver error would cause this? or is it just a random failure? the dude said he was trying to get on it while turning as if pulling out of a side street or something...
yeah just makes me nervous since I just put in a Quaife LSD in my tranny, and I over twice the power this dude had I would like to understand what not to do...
btw, same dude also said he installed a replacement tranny and it did the same thing. now he's having a shop install the tranny so if it goes again he can blame them I guess...
Old Aug 8, 2005 | 01:34 PM
snowseeker's Avatar
Alot of one wheel burnouts and ALOT of powering hard around corners will cause this. Just simply wears out where the spiders ride on the pin. After awhile one of the spiders will bind with the pin and twist off the (key pin?) that holds the spider pin in place. The pin that holds the spiders will than just slide out the side of the diff and take out the case.
Old Aug 8, 2005 | 02:29 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Alot of one wheel burnouts and ALOT of powering hard around corners will cause this. Just simply wears out where the spiders ride on the pin. After awhile one of the spiders will bind with the pin and twist off the (key pin?) that holds the spider pin in place. The pin that holds the spiders will than just slide out the side of the diff and take out the case.</TD></TR></TABLE>
Yup, we usually get them in the winter. They get stuck and keep on zinging them. Finally they zing the differential pin right out. (whoever said that's a shift rod is a dumbass)
Old Aug 8, 2005 | 02:46 PM
ScottEK's Avatar
Default Re: b16 tranny blown on almost stock si...? (Chiovnidca)
That couldn't look anymore exactly like my b16 cable tranny I blew up last year. I'll snap a pic when I get a chance, you would barely be able to tell the two apart.
Old Aug 8, 2005 | 03:16 PM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
(whoever said that's a shift rod is a dumbass)</TD></TR></TABLE>
That was me. Was referring to the shaft sticking out of the tranny in the pic.
Old Aug 8, 2005 | 03:25 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">That was me. Was referring to the shaft sticking out of the tranny in the pic.</TD></TR></TABLE>
That's the differential pin.
Old Aug 8, 2005 | 04:00 PM
snowseeker's Avatar
That's the differential pin. </TD></TR></TABLE>
Nope, shifter shaft. The one that the shift rod (from the shifter itself) bolts to. Not a cable shifted tranny.
Old Aug 8, 2005 | 04:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Nope, shifter shaft. The one that the shift rod (from the shifter itself) bolts to. Not a cable shifted tranny.</TD></TR></TABLE>
Sorry, i'm the dumbass. My glasses are clean now though.
Old Aug 8, 2005 | 06:17 PM
snowseeker's Avatar
Old Aug 9, 2005 | 01:12 AM
slimer007's Avatar
not to change the subject but i'll buy the internals of that tranny off you.
Jap_Spec_Imports
Mar 15, 2009 12:58 PM
dc2much
Apr 29, 2008 04:53 PM
91redteg
Aug 29, 2007 08:54 PM
91redteg
Northwest (Sales)
Aug 29, 2007 08:52 PM
jaydm ferio
Jan 9, 2005 02:34 PM
