switching tranys
Old Jul 29, 2005 | 06:32 AM
Liquid Ice NF's Avatar
Default switching tranys
currently i have a 94' integra LS with an auto tranny. I am dying for a manual transmission. is it worth it to swap out the auto transmisson and get a LS manual tranny?
what else would i need besides the 5spd LS ecu, and tranny?
and what kind of prices am i looking at here? i almost dont want to do it, b/c the cost of labor is gonna killl me.
Old Jul 29, 2005 | 06:35 AM
Jay Blazed's Avatar
clutch and brake pedal , new gauges
unless u know someone who can do it
i am in the same situation but my tranny only has 30k on it
how many miles???
Old Jul 29, 2005 | 06:41 AM
about 115,000
engine runs strong, so i dont want to do a complete swap
Old Jul 29, 2005 | 06:44 AM
Jwbetley's Avatar
Default Re: (Jay Blazed)
You'll need the whole pedal assembly from a 94-01 integra. You do not necessarily need the gauge cluster.
You will need a master slave cylinder and the hydrolic lines with the clutch release fork. You will need a 94-01 flywheel and clutch kit. You will need the whole shift linkage assembly, shifter and shifter mounts. Yes, you will need an ecu along with a clutch switch for your starter. Oh, You will also need a new starter. Auto's and manuals are different.
There is a lot you need. My advice is look around for a salvaged integra and swap out as many parts as you need. A gsr transmission is about $700 for mid-mileage. You may get $250-$300 for your auto trans if your really lucky. This will probably run you about 2000$, maybe 1500$ if your lucky. Search and see wht others are paying. good luck
Old Jul 29, 2005 | 08:09 AM
projectTeG's Avatar
use the search luke!
https://honda-tech.com/zerothread?id=1255332
Alude99
Sep 25, 2007 05:04 PM
95'turbotegra
Nov 28, 2004 06:09 PM
AK77
Aug 24, 2004 07:10 PM
AznInvasion
Sep 12, 2003 06:19 PM
