another 300whp stock block LS - 302whp/280tq
Old Jul 29, 2005 | 06:00 AM
sean's Avatar
Default another 300whp stock block LS - 302whp/280tq
yep yet another 300whp stock block LS. tuning was done by jeff evans with neptune on a dynapack. final #'s came out to be 302whp/280tq @ 16psi on 94 octane. thanks jeff
setup:
stock block LS
not sure on the manifold(looks like shitbyrd)
sc61
3 inch dp
3 inch exhaust
tial 38mm wastegate
spoolin charge pipes
street imports intercooler
rc 550cc injectors
walboro 255lph fuel pump
3bar map sensor
neptune - tuned by jeff evans
the graph:
the car:
man after the tuning the car feels freakin awesome. before neptune i was street tuned with uberdata running 11-12 psi. the car went 12.7@107 on 225/50/15 bfg's on uberdata, hopefully tonight we will see what she does with the neptune and 16psi.
Old Jul 29, 2005 | 06:06 AM
cuin9sec
Guest
Posts: n/a
nice and clean car! mad props. good luck at the track.
Old Jul 29, 2005 | 06:34 AM
vestalfootball72
Guest
Posts: n/a
Default Re: (t67civic)
looks nice. What kind of tranny are you using?
Old Jul 29, 2005 | 06:48 AM
sean's Avatar
Default Re: (vestalfootball72)
97 jdm itr(so same as usdm itr) with clutchmasters stage4 clutch and fidanza flywheel.
Old Jul 29, 2005 | 06:50 AM
blackeg's Avatar
Default Re: (sean)
Old Jul 29, 2005 | 06:51 AM
1boostedcivic's Avatar
Default Re: (sean)
NIce ride and numbers!!!!
Old Jul 29, 2005 | 06:52 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (sean)
dang i jsut tuned me stock LS at 10psi for 250whp and 225ft lbs......no wi wanna turn the boost up.....
great #'s
may i ask what your 1/8 time was? i ran 8.6@84 last night on federal tires... and LS tranny
on the #'s man i want that shyt there...what is done to the "head"
hows it feel with that tranny?
Old Jul 29, 2005 | 10:08 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (Snoflake)
i cant believe it took 16 psi with an sc61 to make 300whp
id be extremely disappointed if i only hit low 300s with 16lbs
whats compression #'s on your motor?
brian (nother ls turbo owner but with t3 60-1)
Old Jul 29, 2005 | 10:45 AM
sean's Avatar
Default Re: (coptzer)
my compression on my motor is fine. the motor is fine. my friend the same day with a stock ls made 299/255 with an sc61 at 15psi. we had different intercoolers, chargepipes and turbo mani's.
also jeffs dyno reads alittle lower, on a dynojet i would have made around 315ish.
Old Jul 29, 2005 | 10:47 AM
project dc2's Avatar
Default Re: (sean)
great numbers !!
Old Jul 29, 2005 | 10:48 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (sean)
when are you getting full boost? 4500?
Old Jul 29, 2005 | 10:51 AM
Stewie's Avatar
sick car keep us updated on track times
sean's Avatar
closer to 5.
Old Jul 29, 2005 | 11:02 AM
Smokinsax's Avatar
The Boot
i love the power curve. should be low 12's now wouldnt you say?
Old Jul 29, 2005 | 11:05 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean &raquo;</TD></TR><TR><TD CLASS="quote">closer to 5.</TD></TR></TABLE>
and reline is 6800 or u taking it higher???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokinsax &raquo;</TD></TR><TR><TD CLASS="quote">i love the power curve. should be low 12's now wouldnt you say?</TD></TR></TABLE>
EASY!
Old Jul 29, 2005 | 11:08 AM
Touge Tuning's Avatar
280tq :O:O thats nuts. What style manifold is it, log, ram-horn, mini-me?
I am going to be turbo'ing my stock LS Block very soon and im looking to make similar numbers and also ill probably make the journey down to jeff for it to be tuned with neptune. Do you think a T3 Super 60 could pull similar numbers with less lag?
Old Jul 29, 2005 | 11:57 AM
sean's Avatar
Default Re: (scarlemthug)
i hope so, im going to run on my bfg's tonight and see how i do. then get my slicks mounted early next week and try for better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake &raquo;</TD></TR><TR><TD CLASS="quote">
and reline is 6800 or u taking it higher???</TD></TR></TABLE>
jeff set it up so that the check engine light comes on and works as a shift light. he set it at 6500 or alittle after so when i do shift its at 7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarlemthug &raquo;</TD></TR><TR><TD CLASS="quote">280tq :O:O thats nuts. What style manifold is it, log, ram-horn, mini-me?
I am going to be turbo'ing my stock LS Block very soon and im looking to make similar numbers and also ill probably make the journey down to jeff for it to be tuned with neptune. Do you think a T3 Super 60 could pull similar numbers with less lag?</TD></TR></TABLE>
not sure about the lag and #'s with that turbo. but i would go see jeff, he is a great tuner.
here is an old *** pic of my mani when it was first put on:
Old Jul 29, 2005 | 12:17 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (sean)
any engine bay shots?
Old Jul 29, 2005 | 12:19 PM
wisjdmhonda's Avatar
Default Re: (blackeg)
Old Jul 29, 2005 | 12:37 PM
nice manifold, thats pretty much the exact same style i want to put on mine. Jeff is definitely a great tuner and id be more than willing to drive down there to get tuned by him, his numbers are always impressive.
Old Jul 29, 2005 | 01:00 PM
lucidvtec's Avatar
very nice numbers...clean civic as well...i'm jealous of your 94 octane....91oct here in AZ...good job
Old Jul 29, 2005 | 01:53 PM
sean's Avatar
Default Re: (lucidvtec)
alright guys, going to the track now. ill post up how i did.
Old Jul 29, 2005 | 01:56 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (sean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean &raquo;</TD></TR><TR><TD CLASS="quote">alright guys, going to the track now. ill post up how i did. </TD></TR></TABLE>
best of LUCK hope it does well onthe BFG's
Old Jul 29, 2005 | 05:14 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">i cant believe it took 16 psi with an sc61 to make 300whp
Oh shut up! you're looking at the HP number torque is always what you want to look at and 280trq at 16PSI on an SC61 is pretty consistent so I see no problems.
225BFG's are what I ride on as well now, but have yet to go to the track. Can't wait to see some more track times from you .
Great job! I remember you posted in my 300+whp thread for my car! Glad we have another beastly LS rolling around.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake &raquo;</TD></TR><TR><TD CLASS="quote">when are you getting full boost? 4500?</TD></TR></TABLE>
wherever torque begins it's straight line (usually also the peak on LS engines because of the head design)
Old Jul 29, 2005 | 05:21 PM
Sohc Driver's Avatar
Default Re: (adseguy)
sweet numbers and an awesome picture of the car man!!
