6psi vs. 10 psi not much difference on my butt?
Old Jul 29, 2005 | 05:49 AM
elpiar's Avatar
Default 6psi vs. 10 psi not much difference on my butt?
I have dual stage boost controller and I know I should dyno my car (haven't had time/money) but after tuning (12 AFR for 6 psi and 11.7 AFR for 10 psi, I feel not much difference between them on my butt dyno..
Is there something wrong with the motor? I don't think there is any leak because I see the boost gage spooling up quick and solid.
Old Jul 29, 2005 | 06:13 AM
beepy's Avatar
Default Re: 6psi vs. 10 psi not much difference on my butt? (elpiar)
Probably a tuning issue. The AFR's are one thing but your timing is also important.
I have noticed in my car, if I floor it I make 11.5:1 AFR at full boost, but if I go partial throttle it will be more like 13:1 at full boost. The car is much quicker with the leaner AFR.
Old Jul 29, 2005 | 06:57 AM
EJ1 wilcox's Avatar
What is your timing like?
You should feel a night and day difference from 6 psi to 10 psi.
Old Jul 29, 2005 | 07:09 AM
elpiar's Avatar
Default Re: 6psi vs. 10 psi not much difference on my butt? (EJ1 wilcox)
on low cam, timing on 6 psi is 21 deg, at 10 psi is 17 deg
on high cam, timing on 6 psi is 27 deg, at 10 psi is 23 deg
I'm running step retard
Old Jul 29, 2005 | 07:14 AM
mrx's Avatar
mrx
interest in it too...
Old Jul 29, 2005 | 09:55 AM
tgreaves's Avatar
Default Re: 6psi vs. 10 psi not much difference on my butt? (mrx)
What size turbo do you have, maybe your maxing it out..
Old Jul 29, 2005 | 10:06 AM
Snail Tuning's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">on low cam, timing on 6 psi is 21 deg, at 10 psi is 17 deg
I'm running step retard </TD></TR></TABLE>
shouldn't this be switched around so your running less degrees under high boost? or am i totaly wronge?
Old Jul 29, 2005 | 10:10 AM
dustin's Avatar
what turbo?
Old Jul 29, 2005 | 10:12 AM
mrx's Avatar
mrx
Default Re: 6psi vs. 10 psi not much difference on my butt? (Snail Tuning)
he is right... ha has less advance on higher boost... just re-read ... but he has more advance on highcam then on lowcam but this is just normal...
i don't think he maxed out his turbo... not at 10psi ... even a T25 should be able to make power at 10psi on our small displacement honda engines.
but tell us the turbo you have... maybe it helps.
whats about boost leaks? i had a car that didn't want to be faster even if i rise boost and it had a boost leak... just a small one but it was one there that causes the problem.
best regards
Malte.
Old Jul 29, 2005 | 01:57 PM
elpiar's Avatar
I've got a T3 .48/.42 on B18C1
Also, for some reason, I feel more torque between 3k to 4.5k, and then not that aggressive until it reaches 6.5k. I know for sure my AFR is tuned flat to 12.5 throughout rpm range. (or 11.8 for 10 psi)
I have stock motor btw, haven't mess around with it since I bought it. It's a 2000 GSR with 95k miles.
Old Jul 29, 2005 | 01:58 PM
elpiar's Avatar
If I can boost fast and consistent (on my boost gage) then there shouldn't be any boost leak right? I mean, even if there is one, the pressure at intake manifold still exist as it is, right?
Old Jul 29, 2005 | 01:59 PM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning &raquo;</TD></TR><TR><TD CLASS="quote">shouldn't this be switched around so your running less degrees under high boost? or am i totaly wronge?</TD></TR></TABLE>
Those are values from uberdata, which refers to the amount of advance before TDC
Old Jul 29, 2005 | 02:06 PM
try adjusting vtec, when is your crossover set at now? you may need to raise it up to keep the torq climbing
Old Jul 29, 2005 | 02:08 PM
elpiar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snail Tuning &raquo;</TD></TR><TR><TD CLASS="quote">try adjusting vtec, when is your crossover set at now? you may need to raise it up to keep the torq climbing</TD></TR></TABLE>
Right now it is at 4.3k, today I set the vtec off to tune low cam basemap again since I cleaned up my filthy air filter.
I haven't tried that yet.
Old Jul 29, 2005 | 09:40 PM
elpiar's Avatar
More persepective?
Old Jul 29, 2005 | 10:54 PM
CRXdan's Avatar
a t3.42/.48 on a gsr?
WAY too smal.
Buy a REAL turbo.
Old Jul 29, 2005 | 11:05 PM
SOHC_MShue's Avatar
Default Re: (CRXdan)
that turbo is way to small for that motor.
Old Jul 30, 2005 | 06:51 AM
vaporboy12's Avatar
Default Re: (SOHC_MShue)
put vtec at 5200k
Old Jul 30, 2005 | 08:20 PM
elpiar's Avatar
If I use t3/t04e when should I expect full boost?
my turbo is really fun to drive now full 6 psi boost at 2500 rpm
Old Jul 30, 2005 | 09:16 PM
StolenTeg's Avatar
Default Re: (elpiar)
fullb oost by 2500 and fall on it face at 6000 and oyu rev to 8000, no wonder it felt the same
Old Jul 30, 2005 | 11:45 PM
elpiar's Avatar
Default Re: (StolenTeg)
The big question is how do I know it's the turbo going out of breath or is it something wrong with my motor?
Old Jul 31, 2005 | 06:44 AM
nonvtecD's Avatar
You know because that turbo is too small for that motor, guaranteed. My non-vtec sohc has a bigger turbo that that.
Old Jul 31, 2005 | 08:00 AM
elpiar's Avatar
Default Re: (nonvtecD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtecD &raquo;</TD></TR><TR><TD CLASS="quote">You know because that turbo is too small for that motor, guaranteed. My non-vtec sohc has a bigger turbo that that.</TD></TR></TABLE>
Maybe if someone can help me read compressor maps and how to determine volumetric efficiency? I've been curious about this topic.
Old Jul 31, 2005 | 10:18 AM
boosted k20's Avatar
the timing seems a little bit too advanced. when i street tune turbo cars on about 10psi, i set the overall timing to be around 19*. then i take the car on the dyno and play with the ignition tables.
get ur cheap *** on a dyno!
Old Jul 31, 2005 | 10:21 AM
Bailhatch's Avatar
Default Re: (boosted k20)
the t3 probably cant keep up in the higher RPMs. A t3/t4 will have a higher boost threshold but you will be rewarded with some real power that holds to redline.
