how hard is it to take out a eg dash?
6 bolts you need to remove:
1. 2 under the side dash covers
2. 1 near the hood latch
3. 1 behind glove box on the right
4. 1 under the top vent
5. 1 behind ashtray console
Parts that need to be removed:
1. Glove box
2. Panel above driver's leg + metal plate thingy
3. Radio
4. Ashtray console
5. Drop the steering column
Wiring harnesses:
1. Remove the three plugs from the fuse box to make dash removal easier
2. Disconnect the two climate control plugs from behind the ashtray console
Now pull your dash out. You'll have a cluster/dash switches and climate control subharnesses that are going to be removed from your dash and placed onto the new dash if you didn't get the subharnesses. Installation is just backwards. Took a friend and me 20 mins to remove his dash.
1. Glove box
3. Radio
4. Ashtray console
Wiring harnesses:
Ya, I've removed my dash so many times it literally takes 10mintues.
With two people, you'll be done in 20-30 min cause it's your first time.
Dropping your steering column is 4 bolts. Not as bad as it may seem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Ya, I've removed my dash so many times it literally takes 10mintues.
Dropping your steering column is 4 bolts. Not as bad as it may seem.</TD></TR></TABLE>
i think the hardest part is people forget the bracket litter ! -
