Why is my steering wheel still shimmying
Old Jul 28, 2005 | 09:38 PM
ShadyBAB's Avatar
Default Why is my steering wheel still shimmying
My steering wheel shimmys pretty bad wether I'm going 15 or 60. I replaced the brakes, got my wheels balanced, put on new axles and boots, new wheel bearings, did my alignment and I put stock suspension on my car which improved a littlebit. But it still shimmys. Any idea what it is?!
Old Jul 28, 2005 | 09:51 PM
Paul Walker's Avatar
Default Re: Why is my steering wheel still shimmying (ShadyBAB)
Look at your calipers or your hubs.
Ensure that the caliper bolts are tight and see if there's play in the hub.
Old Jul 28, 2005 | 09:52 PM
ShadyBAB's Avatar
Default Re: Why is my steering wheel still shimmying (Paul Walker)
Yeah I thought one of my wheels might have been warped, they're just black steelies. New though. bump
Old Jul 28, 2005 | 10:02 PM
dohcdelsol's Avatar
Does it "shimmy" during acceleration/brakeing or just crusing???
What about during turning??? Any difference their?
What tires are you running??? Anything like all season or winter tires with bad wear?
Bad rack n pinion maybe??? cause u replaced alot so far
Old Jul 29, 2005 | 05:20 AM
EE_Chris's Avatar
Tie-rods (inner and outter) or worn shocks.
Old Jul 29, 2005 | 05:39 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Why is my steering wheel still shimmying (EE_Chris)
Definatly check your calipers, as one or both could be grabbing. Jack the car up and make sure the tire is off the ground. Wiggle the tire back and forth, if you feel any play at all, you need to wheel bearings... possibly the hub.
Old Jul 29, 2005 | 05:45 AM
b18blackek's Avatar
How are ur tires? Try rotating or replacing them.
Old Jul 29, 2005 | 06:52 AM
james p.'s Avatar
When and how did this start happening?
Old Jul 29, 2005 | 07:27 AM
nocturnaldragon's Avatar
Mine had a minor shimmy to it one day I pop the hood and noticed that I was missing all three bolts for my transmount. Have no idea how in the hell it happened but that was my proplem.
cash459
Acura TL, RL & ZDX
Aug 18, 2008 02:56 PM
rice_classic
34
Aug 29, 2005 07:46 PM
blackccoupe
May 23, 2005 04:19 PM
BauleyCivic
11
Oct 11, 2004 09:14 PM
Lowball
Aug 1, 2001 09:16 AM
