Suspension & Brakes Theory, alignment, spring rates....
gsr vs itr swaybar endlinks
Old Jul 28, 2005 | 09:29 PM
jetpilot's Avatar
Default gsr vs itr swaybar endlinks
Is there any diference between the two??
Also where can I buy the Dbrakets to mount the swaybar??
Old Jul 28, 2005 | 09:45 PM
veggiemaster's Avatar
Default Re: gsr vs itr swaybar endlinks (jetpilot)
they are technically different, as they have different part numbers, but the itr rear sway will bolt to your endlinks just fine.
and the "dbrakets" im not sure what you are referring to. if you are thinking like a Beaks or BSQ kit, go to http://www.beaksproducts.com or http://geocities.com/bretq/swaybar_install.html for the bsq kit.
you will need to buy the bushings and the bushing brackets from acura though.
Old Jul 28, 2005 | 09:51 PM
jetpilot's Avatar
for the d brackets I was refering to the bushing brackets. Which ones should I get for a 23mm bar??
Old Jul 30, 2005 | 03:43 PM
Default Re: (jetpilot)
oh, well, you will need to get the ITR brackets from acura. As far as the bushings, you can get the OEM ITR bushings as well and then just drill it out to oversize it, or just jam it on.
hvn4life
Oct 7, 2006 01:31 PM
dt4life
Nov 14, 2004 07:24 PM
asmallsol
May 28, 2003 07:14 PM
comptechgsr
Sep 15, 2002 12:00 AM
