6500rpm cut off in a 92' civic with a 95' h22a
Old Jul 28, 2005 | 08:24 PM
Preludes'R'Us's Avatar
Default 6500rpm cut off in a 92' civic with a 95' h22a
I fixed all the codes, now the only code it is throwing is the egr code! I reset the computer, but guess what it is still cutting out at 6500rpm. The only thing my car doesn't have is the resistor box, but it isn't throwing a fuel system code or an injector code. So would the resistor box cause it to cut out early? And it is a p13 mt ECU also. I'm stumped!? I've been haveing this issue for a month and a half.
i bought the resistor box, but I don't want to put it in if I don't have too. I'd rather just take it back to the honda dealer and get my money back. aaaarrrrrgggggg!
Old Jul 29, 2005 | 04:24 AM
v4lu3s's Avatar
RTFM
what injectors do you have?
Old Jul 29, 2005 | 04:50 AM
Slavko's Avatar
Default Re: (v4lu3s)
you need to have the resistor box, its a must!!!!
Old Jul 29, 2005 | 08:34 AM
Default Re: 6500rpm cut off in a 92' civic with a 95' h22a (Preludes'R'Us)
just the stock h22a injectors. Thats got to be it anyways, because thats the last thing I can think it could be.
Old Jul 29, 2005 | 08:42 AM
v4lu3s's Avatar
RTFM
well regardless of whetehr that is it you NEED the resistor box or else you risk burning your ecu. the ecu expects to see 10-12 ohms of resistance, right now it is seeing appr 2 ohms. when you run a amp designed to run at 4 ohms load with a 1 ohm load it tends to get hot and potentially burn up as well... its the same with your ecu and injectors.
Old Jul 29, 2005 | 09:40 AM
UrbanEh's Avatar
I had an HMotor in my old EG with the p13, it used to cut out at 6200 also. I was told that it was a speed governer in the ECU. Maybe you could do a p28 rechipped ece, that would also get rid of your egr CEL. Also, put the resistor box on it would suck to burn up that p13.
Old Jul 29, 2005 | 04:46 PM
Slavko's Avatar
Default Re: 6500rpm cut off in a 92' civic with a 95' h22a (indyEGG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by indyEGG &raquo;</TD></TR><TR><TD CLASS="quote">I had an HMotor in my old EG with the p13, it used to cut out at 6200 also. I was told that it was a speed governer in the ECU. Maybe you could do a p28 rechipped ece, that would also get rid of your egr CEL. Also, put the resistor box on it would suck to burn up that p13.</TD></TR></TABLE>
no such thing as a speed governor on p13 ecu's. The redline on a p13 will work normal as long as everything is hooked up right.
Old Jul 29, 2005 | 05:32 PM
v4lu3s's Avatar
RTFM
jdm p13s have a speed governor at 180km/h
but it wont stop you from revving past the stock rev limit of 7400 rpm.
Old Jul 30, 2005 | 09:47 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">jdm p13s have a speed governor at 180km/h
but it wont stop you from revving past the stock rev limit of 7400 rpm.</TD></TR></TABLE>
correct.
you sure you're letting the car warm up to operating temp before you're flooring it? I know you have to have the car warmed up for VTEC to operate.
LivinDreamsEK9
Mar 26, 2008 07:00 PM
SiR-T
Apr 24, 2006 01:12 PM
lil big iron
Jun 11, 2004 10:07 AM
hman09
Feb 22, 2004 12:38 PM
importimage
10
Aug 26, 2003 06:17 PM
