Speedometer recalibration
Old Feb 19, 2002 | 11:32 AM
bps2799's Avatar
Default Speedometer recalibration
Is it possible to "tune" your VSS to take into account "plus sizing" you tires?
The VSS sounds like a throwaway, non-adjustable item in the service manual, so I wanted some inputs.
I did see there is a tiny input shaft coming in from the tranny to the VSS; can this be adjusted?
Old Feb 19, 2002 | 01:08 PM
Spade's Avatar
Default Re: Speedometer recalibration (bps2799)
NOpe
Old Feb 20, 2002 | 03:56 AM
Mista Bone's Avatar
D Tranny Guru
it is possible, but not very easy.
Only system I've seen cut the VSS signal in 1/2.
Had something to do with what later became Hondata
Old Feb 20, 2002 | 05:56 AM
Greyout's Avatar
Default Re: Speedometer recalibration (Mista Bone)
How much bigger do you want to go, and why?
Old Feb 20, 2002 | 10:55 AM
bps2799's Avatar
Default Re: Speedometer recalibration (JDM LUDE)
Not much bigger, +1. I just would like to be able to adjust the output.
joeking
Honda CR-V & Element
Jul 27, 2017 11:16 AM
no2psi
Jun 24, 2005 04:07 AM
Sketch_hs
Acura TL, RL & ZDX
Mar 25, 2005 07:51 AM
twin pp
Dec 18, 2002 07:19 PM
