DC header
Old Jul 28, 2005 | 07:01 PM
jacobforcecrx's Avatar
Default DC header
I just bought a Dc sports header for a 92-95 civic. The o2 censor is at the very end of the header. If i extend my wire to fit will it bring up a check engine light, because mine is a one wire not 4.
Old Jul 28, 2005 | 07:06 PM
Magick211's Avatar
Default Re: DC header (jacobforcecrx)
Yeah it will work but not as good. The non heated 02 wont get hot enough.
Crx Jimmy's Avatar
put your stock sensor in the back and gently pull the o2 wire(on engine harness) farther out of the loom it will reach
Old Jul 28, 2005 | 07:11 PM
how hard is it to convert to the heated 4 wire
Old Jul 28, 2005 | 07:15 PM
Magick211's Avatar
well basically you need to convert to obd1 to run the 4wire o2
However i have heard of people using 4wire with obd0. I guess they hook the signal wire up like normal and then put power to the heater wires. Dont take my word on this though im not sure exactly how people do it
Old Jul 28, 2005 | 07:23 PM
Default Re: DC header (Magick211)
so how bad will it run with the one wire or will i notice it
Old Jul 28, 2005 | 07:36 PM
Magick211's Avatar
Well i know the 02 needs to get hot to get a good reading. But i had a 1 wire 02 on a 92-95 header and it seemed to run decent
Old Jul 28, 2005 | 07:49 PM
thanks man. If anyone knows how to convert let me know.
Old Jul 28, 2005 | 07:55 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacobforcecrx &raquo;</TD></TR><TR><TD CLASS="quote">thanks man. If anyone knows how to convert let me know. </TD></TR></TABLE> The O2 sensor will be fine, just if you have to extend the wire use a shielded wire. If you want to convert to a four wire oxygen sensor then this is what you do -
CONVERSION -
Oxygen Content --&gt; Oxygen Content
Heater Control --&gt; 12V ignition on
Ground --&gt; Thermostat housing
Old Jul 28, 2005 | 08:08 PM
suspendedHatch's Avatar
Default Re: DC header (dr_latino999)
If you just want the wire to reach the O2 port on the header, don't touch the wiring. Just slit open the split loom and pull the wiring back to about the thermostat, then get some new loom, tape it up, and drop it down to the header. Just did this for a DC on my EG.
Don't touch the wiring unless you can do really good connections. O2 sensor wiring has to be perfect.
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> The O2 sensor will be fine, just if you have to extend the wire use a shielded wire. If you want to convert to a four wire oxygen sensor then this is what you do -
CONVERSION -
Ground --&gt; Thermostat housing</TD></TR></TABLE>
Isn't that going to burn up the heater?
I'd just stick with the 1 wire O2... the heater is just to get the O2 working faster, its emmisions stuff. It is a good idea to run shielded wire, less EMI.
Old Jul 28, 2005 | 08:22 PM
Default Re: DC header (Bunger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that going to burn up the heater?</TD></TR></TABLE> Why would it burn it up? It is only on when the motor is on, and also the heater allows the O2 sensor to be placed anywhere as there is no longer the need for the exhaust gases to produce the correct temperature for the sensor to function correctly.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Don't touch the wiring unless you can do really good connections. O2 sensor wiring has to be perfect.</TD></TR></TABLE> Well then, thank you, my ghetto chop job the first time was better then I thought.
Old Jul 28, 2005 | 08:36 PM
Tyson's Avatar
hold up. i used a 92-95 DC 1 piece header on my CRX and it worked JUST FINE.
o2 sensor was JUST long enough if you routed it over the tranny.
i did not have ANY sensor problems with a bosch replacement sensor. i passed california smog several times with it. i see absolutely no need to use a 4 wire sensor. it gets plenty hot enough.
how many ppl who have commented already actually have used a 92-95 header on their car? it seems a lot of ppl are giving advice on speculation....
Old Jul 29, 2005 | 05:16 AM
Default Re: DC header (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">how many ppl who have commented already actually have used a 92-95 header on their car? it seems a lot of ppl are giving advice on speculation....</TD></TR></TABLE> Well, you caught me there. Mine was a 96-00 so I guess I will have to leave the conversation.
Old Jul 29, 2005 | 08:32 AM
o2 sensor was JUST long enough if you routed it over the tranny. I'll try that and
see how it works. thanks
Old Jul 29, 2005 | 10:00 AM
Tyson's Avatar
oh yeah, the only other issue youre going to have is that the rear mount that holds up the header isnt going to line up wit hthe stock one. i never bothered to find a way to support it. i just left it alone.
although, ive been told its best to use that because then all the support is at the exhaust manifold bolts and gasket at the head, holding up the whole exhaust pipes. which will cause a lot of stress and vibration and rattling since the rest of the ehxuast is just loosely suspended. i never had a problem, but i feel that i have to explain that to you anyway.
maybe if you get thee z6 support bar itll fit properly... or just fab up your own.
Old Jul 29, 2005 | 12:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, the only other issue youre going to have is that the rear mount that holds up the header isnt going to line up wit hthe stock one. i never bothered to find a way to support it. i just left it alone.
</TD></TR></TABLE> What you can do is only mount one bolt to the block, so that way it extends a bit. That way both bolts will attach to the header supporting it.
Old Jul 29, 2005 | 09:44 PM
my bracket is already cut off on the header. so i'll look into fabn' one.just worried if the engine light will come on but every bit of info helps.
suzieffbaby
Oct 26, 2012 02:04 PM
andrey320
18
Jun 25, 2006 09:01 AM
AZTEKEF9
11
Aug 8, 2005 12:13 PM
variable
Aug 6, 2005 12:37 PM
sikcrx80
Apr 10, 2003 01:52 PM
