How to fit a d16a6(89Si) trans on a 94 auto?
I have a 89 Si trans but its a cable clutch. I have a auto on my 94. The wrecking yards in my area suck and want too much $ if the cars still have parts on them. I can probably find more parts of a 88-91 cable clutch. What would I need to convert my 94 auto to make use of a d series cable clutch?
reweld a tranny mount on the body, then I would suggest getting a hydro tranny, way cheaper to convert. 5spd brake and clutch pedal assebly, clutch master cylinder, hydro lines, slave cylinder, tranny mount on the tranny, flywheel, clutch, clutch fork, chip your ecu so it won't idle like **** and won't throw a code (easy), rewire park/nuetral switch.
cable tranny will make you spend more money, cable/hydro adapter is like $250 I believe.
lilo_goki
13
May 9, 2007 10:34 AM
95 vtec
Nov 14, 2006 08:35 PM
LittleDevilBmx
Aug 2, 2005 07:28 PM
xlusiveracer
Feb 28, 2005 02:32 AM
