what turbo should i get?
hey everyone i got a rt awd wagon ang i got a type r motor and tranny in it. everything in the motor has been worked on. am making almost 300hp with no turbo. in 1\4 am in the low 12s. i want to put a turbo in it i what to know which one u think its best and how much psi should i run and is it worth it because it i put a lot of money into the engine i dont want to ruin it. what u guys think
Well what did you do to the rear first they are known from blowing easly at 200 HP let alone 300.
What is your current setup to get 300 WHP n/a I am guessing?
What are your goals and budget.
Yea somthing seems fishy on your whole setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric123121212 »</TD></TR><TR><TD CLASS="quote">well its not a rtawd anymore i mentioned it had type r tranny aswell. </TD></TR></TABLE>
Ohh ok your first post didn't talk about you removing the prop shaft so its just FF now.
still goals budgets current setup will be needed.
it has a skunk2 intake manifold
directport nos 75 shot
basically the head is all skunk2
dart block
forged pistons high compression
aem cold air intake
and more
money is not a issue
dart block
aem cold air intake
and more
Thats fine man.
umm
a good sized t3/t4 could do that or even a disco potato.
dig around the F/I area and look at setups there it helps alot.
You will need new pistons and maybe cams.
umm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulangot »</TD></TR><TR><TD CLASS="quote">the BS flag is up...</TD></TR></TABLE>
u are right
u are right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eric123121212 »</TD></TR><TR><TD CLASS="quote">thats it noone likes my wagon
Uhhh..I guess?
The setup sounds interesting, but I gotta see it to believe it.
</TD></TR></TABLE>Uhhh..I guess?
?The setup sounds interesting, but I gotta see it to believe it.
what are you currenty trapping in the 1/4? (MPH) You should consider suspension and better slicks ... at 300HP all motor, you should be damn near close to 11.1-3
You put a built Type R motor and tranny into a Civic wagon with "cut" springs?
I think you are either a little "nuts" or are trying to BS us.
