ZC DOmed Pistons
Old Jul 28, 2005 | 06:10 PM
EF9SIRJeff's Avatar
Default ZC DOmed Pistons
I have a D1616
Thinking about putting in ZC domed pistons
BUT i know its best to re hone the block
Is this absolutly needed??????????
Or can I do it with out taking my block to a machine shop ????
would like to just pull old ones and plug in the new ones
thanks
Jeff
Old Jul 28, 2005 | 06:18 PM
kulangot's Avatar
Default Re: ZC DOmed Pistons (EF9SIRJeff)
i would..
Old Jul 28, 2005 | 06:19 PM
dr_latino999's Avatar
You have to have a fresh hone or your new rings will not seat right.
Old Jul 28, 2005 | 06:46 PM
EF9SIRJeff's Avatar
i have about a 50 - 50 say i have to some say i dont just lookin for a few more opinions
BUMP
Old Aug 1, 2005 | 08:27 PM
EF9SIRJeff's Avatar
Still looking for more opinions please
curious if anyone has ever swaped out pistons without a honed block
what happened when you did Etc >>>>>>>>>
Old Aug 1, 2005 | 08:33 PM
Hamstr323's Avatar
Default Re: ZC DOmed Pistons (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">You have to have a fresh hone or your new rings will not seat right.</TD></TR></TABLE>
Old Aug 1, 2005 | 08:40 PM
EF9SIRJeff's Avatar
Yes i realisze this thank you i read it when first person wrote it
i wsa curious if anyone had ever swaped out pistons without honing a block and also
How much should i except to get my block honed cuz it its too much im just getting a B18
Old Aug 1, 2005 | 09:10 PM
EFdrag4life723's Avatar
well my bro swaped piston out in his 4g63 mitsu and replaced every thing new i mean every thing but he didnt hone his block and it smoke and dosent have the best compression he should it will be fine at frist but after a while the ring good bad a hole lot quick ive built a few motor i hone every one of them and never a prob. ne its cheap insurence.
good luck bro
Old Aug 1, 2005 | 09:40 PM
Malgerus's Avatar
And if the crosshatch is worn on your bores, the rings will not get sufficient oiling and you could have serious issues later on down the road.
Old Aug 2, 2005 | 03:37 AM
1G_DX_to_2G_Si's Avatar
hone the damn block, noone said performance was cheap.
Old Aug 2, 2005 | 04:45 AM
davens's Avatar
Default Re: ZC DOmed Pistons (EFdrag4life723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFdrag4life723 &raquo;</TD></TR><TR><TD CLASS="quote">well my bro swaped piston out in his 4g63 mitsu and replaced every thing new i mean every thing but he didnt hone his block and it smoke and dosent have the best compression he should it will be fine at frist but after a while the ring good bad a hole lot quick ive built a few motor i hone every one of them and never a prob. ne its cheap insurence.
Well said.
Old Aug 2, 2005 | 06:28 AM
EP3_05's Avatar
I agree with everyone else in this thread...get it honed or you will be paying for it in the end with lots of smoke and low compression. I remember a while back I helped a friend rebuild an old d15 and he decided to be cheap and just throw new rings and pistons in the block without a hone. It was ok at first but it started to burn oil and smoke like crazy. Needless to say he ended up rebuilding it right the second time around.
Old Aug 2, 2005 | 09:26 AM
HumanResource's Avatar
If you're using new rings (which you SHOULD), then get a rehone.
If you don't, there's a GOOD chance you won't get a good seal ESPECIALLY w/ our trick Chromed faced HONDA rings.
what's the use of HIGH compression with 50% leak down???
apekd
Mar 26, 2009 11:20 AM
QBANBOY407
Aug 11, 2008 06:26 PM
kyosoeg6
Jan 18, 2004 06:31 AM
SMSP
Sep 15, 2003 03:21 PM
Lamchop0000
Jul 15, 2002 08:07 AM
