89 crx si with a 95 vtec head swap
anything i would need to change to make it fit or should it be a direct bolt in? i know what i need from the 95 civic. but is there anything i will have to do beside swap the heads... throttle bodies... an ecu?
Basics - https://honda-tech.com/zerothread?id=554053
Don't forget for it run properly OEM goodness you will either have to chip a 90-91 PM6 with P28 Maps or convert to OBD-1.
It will be fine, but you will have to convert to OBD-1 to use it.
Options -
Purchase Jumper - http://www.rywire.com
D.I.Y. - https://honda-tech.com/zerothread?id=1319235
Options -
dashskier540
Apr 3, 2006 08:10 PM
