How to tune my amp?
I was wondering how I should tune this JL 300/2 amp if I was hooking it up to Two 10" Kicker L5's.
Here is a link to show the picture of the amp
http://www.jlaudio.com/amps/pdfs/300_2.pdf
in my opinion your are gonna want a bigger amp than that. You need at least 600 watts rms for them but if you look at the gain setting flash and the eq flash on the page below your find the info needed http://www.jlaudio.com/amps/amp_pdfs.html#
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrjrsc »</TD></TR><TR><TD CLASS="quote">in my opinion your are gonna want a bigger amp than that. You need at least 600 watts rms for them but if you look at the gain setting flash and the eq flash on the page below your find the info needed http://www.jlaudio.com/amps/amp_pdfs.html#
</TD></TR></TABLE> Ditto the above. Although a very good amp, you are going to need a lot more to power to run 2 L5s RMS is 450 (900 peak] you have 300 rms, not enough to drive one S10L5, you may want to look at the 1000/1 or another sub/subs, the JL Audio 300/2 will make 300 watts RMS into 3 to 8 ohms when bridged
94
94
Dub C
Audio / Security / Video
Feb 7, 2006 07:15 PM
EVIL_AWD
13
Jul 18, 2003 12:14 PM
