Sound Deadening Material Removal
Old Jul 28, 2005 | 04:37 PM
Integra21's Avatar
Default Sound Deadening Material Removal
I started to take out the material that would be under the rear driver's side seat. No dry ice, no heat gun, just brawn!! lol
i got everything out and cleaned up pretty well except for the tar that was over the sealing material.
Rear Pass Side
Rear Driver Side
Both
Can anyone help me out on what to do?
Does anyone have pics of this same area that has be done perfect??
Thanks!
btw: Got bored, i know 20-30lbs will not make any difference really
Old Jul 28, 2005 | 04:43 PM
240sxDrift's Avatar
Default Re: Sound Deadening Material Removal (Integra21)
use Dry Ice
Old Jul 28, 2005 | 04:50 PM
Integra21's Avatar
Default Re: Sound Deadening Material Removal (240sxDrift)
use dry ice over the white sealer? wouldnt that not be good for it?
btw: im not asking how to do it faster...
Old Jul 28, 2005 | 04:54 PM
Taristin's Avatar
Be careful if you use dry ice. I've read it'll make the undercoating flake off, underneath your car.
Old Jul 28, 2005 | 04:59 PM
Integra21's Avatar
Default Re: (Taristin)
i don't plan on using dry ice if i don't have to
BTW: i disagree DC2 > DC4 lol - i have owned both though
Old Jul 28, 2005 | 08:32 PM
Integra21's Avatar
Default Re: (Integra21)
bump
Old Jul 28, 2005 | 09:21 PM
DeeCeeTwo's Avatar
that metal support is alot of weight too, if ur doing reduction.
Old Jul 28, 2005 | 09:24 PM
Integra21's Avatar
Default Re: (DeeCeeTwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeCeeTwo &raquo;</TD></TR><TR><TD CLASS="quote">that metal support is alot of weight too, if ur doing reduction.</TD></TR></TABLE>
yea it is, im taking this piece by piece, not looking to make a day/weekend out of it. but ill try tp weight everything when im done
HELP WITH THE CAULKING!!! what purpose does it serve?
Old Jul 28, 2005 | 10:05 PM
ngogsr's Avatar
whats the point.....u probably save a couple of grams.....u should start w/seats, all panels, carpet n maybe some lexan if u want to see any actual weight reduction
Old Jul 28, 2005 | 10:33 PM
apok's Avatar
Default Re: (ngogsr)
They sell sound deadening remover at some stores. I have no clue what its made of, but it will make the material dissolve to liquid so you can scrape it off fairly easily.
Or, use a heatgun. Works like dry ice.
Old Jul 29, 2005 | 05:12 AM
Integra21's Avatar
Default Re: (apok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr &raquo;</TD></TR><TR><TD CLASS="quote">whats the point.....u probably save a couple of grams.....u should start w/seats, all panels, carpet n maybe some lexan if u want to see any actual weight reduction</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 &raquo;</TD></TR><TR><TD CLASS="quote">
btw: Got bored, i know 20-30lbs will not make any difference really</TD></TR></TABLE>
i need help figuring out how to remove the black tar off of the white caulking! thanks
Old Aug 4, 2005 | 04:05 PM
ngogsr's Avatar
flat head n a hammer, then sand it down
Old Aug 4, 2005 | 07:01 PM
HaTa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr &raquo;</TD></TR><TR><TD CLASS="quote">flat head n a hammer, then sand it down</TD></TR></TABLE>Thats what I did I hammered it out then hit it with a wire brush, now Im going to lightly sand then paint.
Old Aug 4, 2005 | 07:19 PM
Sifu's Avatar
How did you remove the sound deadening in the first place? just a hammer and chisel?
Old Aug 4, 2005 | 07:22 PM
ME=ADRIAN's Avatar
Default Re: (Sifu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sifu &raquo;</TD></TR><TR><TD CLASS="quote">How did you remove the sound deadening in the first place? just a hammer and chisel?</TD></TR></TABLE>
thats how i did it and it just came off i big chunks
Old Aug 4, 2005 | 07:44 PM
Sifu's Avatar
How long did it take bro? I was always under the impression that it was impossible to do it under that way
Gotta try it this weekend
Old Aug 4, 2005 | 07:45 PM
Tweakmeister's Avatar
Default Re: (DRAPESTER)
I hear 3m Tar Remover works well.
I would be very careful around the seem sealed areas - they are there for structural integrity.
Old Aug 4, 2005 | 07:46 PM
Integra21's Avatar
Default Re: (Sifu)
i used a putty knife... and WD-40 to clean off all the left over tar.. works well
Old Aug 4, 2005 | 07:49 PM
WD-40 is Mineral Oil and a Mild Solvent...might work
Old Aug 4, 2005 | 07:51 PM
Integra21's Avatar
Default Re: (Tweakmeister)
it works REALLY well for clean-up when you have the excess after scraping off the large chunks
Old Aug 4, 2005 | 08:02 PM
matman4444's Avatar
just cut out the entire floor board right? then it will be super light
Old Aug 5, 2005 | 10:13 AM
Default Re: (matman4444)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matman4444 &raquo;</TD></TR><TR><TD CLASS="quote">just cut out the entire floor board right? then it will be super light</TD></TR></TABLE>
As funny as this sounds, I've thought about doing it to the trunk. Unfortunately, the entire chassis is the frame, so removing a little metal weakens everything.
Old Aug 5, 2005 | 11:18 AM
young noob's Avatar
https://honda-tech.com/zerothread?id=525936
everything you need to know to get that damn tar off, and you will only save like 10-15 pounds, but im doing it any way too.........every pound counts
Old Aug 5, 2005 | 01:44 PM
DC2 to AP2's Avatar
Default Re: (young noob)
heres mine.. i used dryice, 3m general, adhesive remover, putty knife, and a hammer/rubber mallet. here are the results...
the white caulking thing you are talking about is a SEAM SEALER.
Old Aug 5, 2005 | 04:43 PM
Squad1's Avatar
just peeld mine off..
