code 15 searched...wont start
Old Jul 28, 2005 | 02:52 PM
nwrallyciv's Avatar
Default code 15 searched...wont start
the car is a stock dpfi 91 std hatch. the problem is the car starts up and runs fine when the engine is cold, but after it runs for about 10 minutes and the engine gets hot, the engine suddenly dies, with no sputtering whatsoever. the ecu gives me a code 15. i checked for spark and noticed that the engine wasnt getting spark which makes sense because code 15 is ignition output signal. i put a new coil and igniter in the distributor as well as cleaned up most of the wiring connections, but the problem hasn't changed. i also clear the ecu memory after every attempt. does anybody out there know whats wrong with my car or some things i can try?
Old Jul 28, 2005 | 04:00 PM
dr_latino999's Avatar
Default Re: code 15 searched...wont start (nwrallyciv)
Check all your wire connections, check ignitor as per service manual, and if all turns up normal try a known good DPFI computer, they are a dime a dozen
Old Jul 28, 2005 | 04:02 PM
crxmrder's Avatar
dude, i had a code 15 on my dohc zc swap for a while i ended up replacing everythin i could. then decided to replace my REBUILT dizzy for a new one and it fixed the problem
Old Jul 29, 2005 | 09:06 AM
insanecreations's Avatar
Default Re: (crxmrder)
i did the same,and it still did it untill i replaced the ecu
Old Jul 29, 2005 | 11:36 AM
deserthonda's Avatar
code 15 is dizzy code mainly ignitor did you replace it with honda parts ??..also make sure all the connections are tight on ignitor and coil
Old Jul 29, 2005 | 03:51 PM
nwrallyciv's Avatar
Default Re: code 15 searched...wont start (deserthonda)
no i didnt use honda parts, its just the carquest brand... i understand the honda parts are quite expensive. i have a feeling its got to be a bad sensor or something. i de-pinned and cleaned all related connectors that i could and went through the distributor and tightened everything up. i guess i'll just try a known good distributor and if that dont fix it i'll try that with a known good ecu.
901Accord
Jun 7, 2017 02:22 PM
xwhitchx
Jan 7, 2012 03:41 PM
sircrx615
Mar 25, 2011 08:01 AM
90crvtec
Aug 19, 2005 07:19 PM
rasta420
29
Oct 23, 2003 03:32 PM
