Ls Motor/B16 Tranny in 91 Dx
Old Jul 28, 2005 | 12:30 PM
LoneAutosport's Avatar
Default Ls Motor/B16 Tranny in 91 Dx
Im planning on putting a b18a with a Y1 tranny in my 91 civic hatchback Dx. I was wondering what i need and what type of modifications i need to make it fit. I know i need mounts and i'm going to use the wiring harness that is already on the car.
Old Jul 28, 2005 | 12:33 PM
EP3_05's Avatar
Default Re: Ls Motor/B16 Tranny in 91 Dx (LsBack!)
You need to convert to mpfi.
Motor mounts and shift linkage. (HAsport, HCP, etc)
It is a pretty straightforward swap.
For more info search for droppedcrxsi...I believe he has a nice b series install how to.
Old Jul 28, 2005 | 12:37 PM
Default Re: Ls Motor/B16 Tranny in 91 Dx (91civic)
It's already wired for MPFI.
Old Jul 28, 2005 | 12:44 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsBack! &raquo;</TD></TR><TR><TD CLASS="quote">It's already wired for MPFI. </TD></TR></TABLE> Then all you need is hasport/hcp mounts, shiftlinkage,90-93 teg axles and jackshaft, integra throttle cable and radriator hoses,obd0 pr4 ecu and your good to go, You should be able to finish this swap in a day
Old Jul 28, 2005 | 12:48 PM
Default Re: Ls Motor/B16 Tranny in 91 Dx (PURPLETERROR)
I've heard that you have to bang out the crossmember for the motor to fit?
Old Jul 28, 2005 | 12:51 PM
EP3_05's Avatar
You need to bend the lip of the rear crossmember to clear the rear mount bracket. You also need to dent the drivers frame rail to clear the alternator or run a shorter alternator belt.
Old Jul 28, 2005 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">You need to bend the lip of the rear crossmember to clear the rear mount bracket. You also need to dent the drivers frame rail to clear the alternator or run a shorter alternator belt.</TD></TR></TABLE>
Ok bend the lip on the crossmember and get hit the frame rail to clear the alt.
Old Jul 28, 2005 | 03:02 PM
How much would all this cost me?
sam0218
Nov 9, 2006 05:46 PM
VtecSyndrome
16
Jan 29, 2006 09:55 PM
fitboy
Oct 6, 2004 02:19 PM
shoebox
12
Jan 6, 2003 03:05 PM
