A/C Compressor Cluth problem
Old Jul 28, 2005 | 10:59 AM
fusionpastor's Avatar
Default A/C Compressor Cluth problem
I have a 97 Civic DX with roughly 162000 miles on it. Last summer the air stopped blowing cold. I went to fix it today, finally, and I noticed the clutch wasn't engaging. However, I sprayed it with lubricant and tapped it, and it kicked in and worked just fine. So, has it just rusted or should I replace the clutch...and if so, how much does one usually cost a brother?
Old Jul 28, 2005 | 11:10 AM
RCautoworks's Avatar
Default Re: A/C Compressor Cluth problem (fusionpastor)
Does it still work normally ? If so don't replace it.
Old Jul 28, 2005 | 11:16 AM
Default Re: A/C Compressor Cluth problem (90blackcrx)
Yeah, when I tap it with screw driver, it kicks right on. But what would be causing it to catch?
Old Jul 28, 2005 | 11:17 AM
Could be rusted, if you have to tap it then defintly get a new one. Check to see if you are getting the correct volts applyed to it.
Gary Fielding
Honda Civic (2006 - 2015)
Jul 4, 2016 06:37 AM
paulbragin
Aug 23, 2014 03:22 PM
einzelherz
Aug 28, 2008 04:19 AM
jdm5lughatch
Jul 9, 2004 06:48 AM
